Recall letter CPS
Old Jan 11, 2008 | 10:00 AM
  #31
WILDMAN_Stroker*7.3's Avatar
WILDMAN_Stroker*7.3
anytime, I just appreciate all the great help that I get from this fourm.
Old Jan 11, 2008 | 12:47 PM
  #32
PSDLOVER's Avatar
PSDLOVER
I went to the dealer and got a new one which really made a positive difference for me. I don't know if they did anything else while I was there. I still have a black one in the glove box from International that cost me like $90 five years ago.
Old Jan 11, 2008 | 01:48 PM
  #33
tjbeggs's Avatar
tjbeggs
TO be very honest unless you are having any issue with your CPS now I would wait until it starts to givr you problems. I got mine replaced that was having no issues. The first new gray sensor last 24 hours before I had to put my spare in to have them replace it again. The second is also having issues. It very well may be that the connector or the wiring is the issue. I put my spare in again last Monday and have had no hiccups since. Also the second CPS was installed and the o-ring was cut in half and leaking oil when I changed it out!
Don't fix it unless its broke is my advice!
Old Jan 11, 2008 | 08:16 PM
  #34
sand1's Avatar
sand1
i didnt have a letter went to dealer and had it replaced and fuel system recall fixed at no charge its a safety issue with the cps they have to fix it or be sued if something happens
Old Jan 11, 2008 | 08:20 PM
  #35
Markadeck's Avatar
Markadeck
Gone, but not forgotten
Off topic, but I like this signature so much that I finally have to say something about it. Now on topic, why I have not done the recall is as much a mystery to me as why either that joke Carter, or the laugh of the century Gore ever receiver the below mentioned.
The Nobel Peace Prize is now equal to a Cracker Jack prize!!
Old Jan 11, 2008 | 08:32 PM
  #36
randomhero1172's Avatar
randomhero1172
What would be some symptoms of a going bad, or bad CPS?
This morning it was about 40* and my truck started just fine, let it warm up for about 2-3 minutes. When i gave it gas it responded with about a 500RPM increase and then the fell suddenly and died. Then started back up and had to depress accelerator fully to keep the truck from dieing (would not idle without dieing) the tachometer was going a tad crazy and would often go from 3,000 randomly and shoot back down to 500 and barely run. After it warmed up it ran great and started great the rest of the day. I feel its not a Glowplug issue because it starts fine. Thanks for the hellp!
Old Jan 11, 2008 | 08:47 PM
  #37
Jim Rowley's Avatar
Jim Rowley
Way off topic but helpfull anyway. Anybody wonder how to type in the degree symbol? Well, here it is. Alt 2 4 8. Go ahead, try it. It's cool, about 40° cool.
Jim.
Old Jan 11, 2008 | 09:08 PM
  #38
zx250's Avatar
zx250
Of the next Riffraff East
I did try it and my computer must be broke. Don't work and I don't know what I am doing, but it would be cool if I figure that out.
Old Jan 11, 2008 | 09:14 PM
  #39
tjbeggs's Avatar
tjbeggs
CPS syptoms include bucking, jerking, hiccup, stall, no start. Those are the normal ones. strange ones include stalling when hitting the brake with a trailer hooked up, poor fuel mileage, rough running, etc.
Your symptoms sound alot like a rubbed thru wire where the main engine harness goes over the driverside valve cover. Check the harness where the wire loom doesn't cover the wire and you may find a wire or two with the insulation rubbed through.
Old Jan 11, 2008 | 09:15 PM
  #40
tjbeggs's Avatar
tjbeggs
same here. No go.
Old Jan 11, 2008 | 09:18 PM
  #41
Jim Rowley's Avatar
Jim Rowley
Are you using the ten key on the right side of your keyboard? Make sure the number lock is on. And if you want the diameter symbol, it's alt 0 2 4 8, ø. No, I don't have a lot of free time. I use these occasionally.
Jim.
Old Jan 11, 2008 | 09:21 PM
  #42
tjbeggs's Avatar
tjbeggs
Well there we go works now!! thanks!!
Old Jan 11, 2008 | 10:09 PM
  #43
zx250's Avatar
zx250
I still don't get it, I know, I'm the slow learner, I rode the short bus to computer school. Plus I using a notebook with numbers across the top if that matters.
Old Jan 11, 2008 | 10:19 PM
  #44
bdrummonds's Avatar
bdrummonds
Barry, look over on the MJKLUIO789 do each of those keys also have a number on them? On my ThinkPad that is where my 10 keypad is.
Old Jan 11, 2008 | 10:20 PM
  #45
randomhero1172
Thanks Beggs! ill check it out, btw i cant get the Degree sign either - and im using a notebook.
