1966 - 1977 Early Broncos
Bronco help asap
Old Jan 14, 2008 | 11:59 PM
RCrawler's Avatar
RCrawler
Yeah, but go back and look at the model, trim level and options. Nothing that pertains to the early Bronco. They show available engines as 390, 351, 429, 460 etc. And no Bronco came with factory air conditioning. Only dealer installed. So I wouldn't trust NADA on this one. The only way to get an accurate value is to have it inspected and appraised by a Bronco expert.
Jason
Old Jan 17, 2008 | 09:40 PM
Boba Fett's Avatar
Boba Fett
You gotta look at a lot of Broncos to get an idea of what a good one is and what a bad one is.
The bronco without an engine that was sitting under a tree on farmers bob's place for 30 years where the top is black with tree crudd to the point you can't see inside the windows might be the deal of the century because it's sheetmetal body structure is intact, where as the white Bronco you put up could be a member of the Bondo brigade and when all the fiberglass and filled fall off the thing in five years you will have the disappearing car.
Rot and rusting into the air is as big a part of these things as it is for 80s Toyota pickups.
You need to look at 20+ vehicles from shells and basket cases to shining restos to get an idea of what to look for an where.
5.0 Heaven
Aug 20, 2015 07:21 PM
wolffee
Nov 13, 2013 06:22 AM
Bubba Jones
1978 - 1996 Big Bronco
16
Aug 20, 2013 01:22 PM
hasseled
Bronco II
Aug 15, 2012 01:15 PM
adelyser
Mar 30, 2002 07:28 AM
