Unique Lowering Method - Flipped Front Axle
Old Jan 17, 2008 | 03:00 PM
matt2491's Avatar
matt2491
So no one know besides Tiremine has ever welded to these axles?
Old Jan 18, 2008 | 02:10 PM
Dragmatic's Avatar
Dragmatic
Why is it that my truck sits just about as low now as some of these that are lowered and it hasn't been touched?
Old Jan 18, 2008 | 03:00 PM
gangstakr's Avatar
gangstakr
let see some pictures!
Old Jan 18, 2008 | 03:05 PM
garbz2's Avatar
garbz2
Welded up plenty of A and duce axles......Just not any slick ones with that mod.
Needs the attention of a TIG welder and skill.
Garbz
Old Jan 18, 2008 | 03:06 PM
garbz2's Avatar
garbz2
Some one let the air out of the tires?
Garbz
Hey Bob... Picked up a new T45 and a cammer for the uni build.......
Old Jan 18, 2008 | 03:25 PM
matt2491's Avatar
matt2491
Actually I think its just how you are seeing it. For example, when I saw the first pic of Tiremine's truck (lowered 6"), I really didn't think his was any lower at mine first - until I took a good look at it. It's weird, but I would look at the distance from the bumper to the ground and swear it wasn't 6" less than my height. But then when I see the wheels just barely tucked under the fender, then I begin to really see it. I don't know, this is just what I think.
Unless they are really really low (like a few inches off the ground or less), I generally don't notice the height. Weirdness...
Old Nov 29, 2019 | 01:09 PM
Jerry Workman's Avatar
Jerry Workman
4th Gear
Originally Posted by matt2491
The original y-blocks in these trucks (at least in mine..), has the oil pump pretty far back in the corner of the engine, not near the axle at all... Also, because the y-block already has such a deep skirt, notching the oil pan shouldn't be a big deal.
The way I see it, if one were willing to do the work, this method could be a viable option.
What would need to be done:
- Weld steel plates (probably 3/8"?) beneath axle.
- Notch frame about an inch or two. Box it in for strength.
- Notch the oil pan.
I think the work may outweigh the cost of dropping it any other ways. Plus, this gets you a good 6" drop, while a $400 dropped axle could get you half of that. And IFS is in the thousands...
Either way, I'll be very interested to read Steve's response to my questions. Especially about any safety issues...
Will this work for me I have a 47 Ford 1 ton with the stock flathead in it THANK'S. 🇺🇸 😎
Old Nov 29, 2019 | 04:34 PM
Cheddar's Avatar
Cheddar
You could always use bolts with no washers instead of the u-bolts and have shackle plates underneath so the nuts can be at the bottom, you would regain 3/4" to 1" of travel space, with carriage bolts you get even more.
Old Nov 29, 2019 | 08:41 PM
cosmofennema's Avatar
cosmofennema
You could. And you could also notice that the axle is now sitting on a bead, not a flat surface. And you might also notice that the leverage to roll this axle has now increased by a large amount. And you might think this is dangerous.
But, what do I know??
Your truck, your money. But, please, do like most rat rodders - drive the truck onto a hidden nearby trailer after the show.
Old Nov 30, 2019 | 07:20 AM
Cheddar's Avatar
Cheddar
He says he's been driving it for years, I bet dollars to doughnuts he has a hole in that plate to sit over the bead. I for one have no interest in lowering my truck one iota, not would I do it this way if I did but when I saw the picture I figured the he could gain some space. And yes people are simply crazy for whatever reason…
flhx06
Aug 28, 2017 02:21 PM
87notch
Dec 25, 2010 10:03 PM
mfire138
Apr 16, 2009 08:13 AM
evil64
Jul 28, 2006 10:28 AM
blatherskite
Jun 18, 2004 02:35 AM
