Sponsored by: Real Truck
Gross Combined Weight?
Old Jan 23, 2008 | 06:12 PM
Passin Thru's Avatar
Passin Thru
BTW: Its coming to your home state. FL now requires ALL pickups to pull into Scales on I95 $$$
Old Jan 23, 2008 | 08:36 PM
Simoncx's Avatar
Simoncx
Bascially if your pulling 1. trailer over 10k 2. truck or truck and trailer are more then 26,001 pounds your in cdl terroity. As far as derating a trailer, dot goes by what trailer axles are rated for, it does not matter if you derate a 14k trailer to 7k there still going to see it as 14k. The only thing with the trailer law is each state looks at it different in nj I can pull a trailer over 10k as long as combined gvw is under 26k, if I cross to ny or mass they look at it if the trailer is 10k and over I can be under 26k and still need a cdl. Personally I think it's better to be safe and have a cdl if your pulling more then 10k trailer because dot fines are very high and if they say you need a cdl you won't be able to move your truck until someone with a cdl can drive it for you.
Old Jan 23, 2008 | 10:45 PM
Passin Thru
FL does'nt care about the CDL on small pickups but they are another source of revenue. I am aware of DOT rules as I own my own trucking CO. VA is stopping pickups if they think they are overloaded and if you are and live in VA it's a $2500-3000 fine
Haestings
All Things Towing
32
Jan 25, 2025 11:12 AM
93-331-29PSI
6.7L Power Stroke Diesel
Dec 10, 2015 12:04 PM
mwilliams0326
All Things Towing
Nov 19, 2015 10:53 AM
bigredtruckmi
All Things Towing
28
Feb 25, 2014 06:49 AM
Poor'it in'her
All Things Towing
Jan 1, 2014 07:55 AM
