1994 f250 turbo diesel, idi
Old Jul 30, 2013 | 09:10 PM
  #31
KrautBurner's Avatar
KrautBurner
Originally Posted by flainn
The Banks round downpipe is 51203 and Summit Racing has them.
so,
this one here http://www.summitracing.com/parts/gbe-52103 bolts right up?
Old Jul 30, 2013 | 09:11 PM
  #32
KrautBurner
Originally Posted by hairyboxnoogle
Thanks flainn.
If you can afford some downtime, pull the exhaust elbow off the turbo and send it to Justin at idiperformance.com (member RacinNdrummin on here) and he will mill the end off and weld on a 3" marmon flange. The downpipe is 3" but the outlet at the turbo is still 2.25 or 2.5" so to get maximum potential there, you need to open up the elbow. Of course you can do this later as well, but since youre going to be working on it right there and have the DP out and everything it would sure be easier i would imagine.
Sure thing.
I'm interested in doing that to my 093. Do you know what Justin charges for this service?
I too would like to know what this would run
Old Apr 13, 2014 | 04:35 PM
  #33
kelsodiesel's Avatar
kelsodiesel
thanks for the info, I definitely need the downpipe, but I need another pipe also and don't know what it is called or where to get it. it's the pipe that goes from the manifold crossover pipe up to the turbo. Correct me if I'm wrong (this is my first diesel) but the down pipe is the pipe coming out of the turbo that connects to the "muffler pipe".
Old Apr 21, 2014 | 01:40 PM
  #34
kelsodiesel
94 turbo IDI exhaust replacement
I need to replace the exhaust on my 94 F250. I was told to use a 4" exhaust by all of the exhaust companies in my area but I was also informed that 4" would be to big and not run up to temp and that would cause soot and carbon build up in the pipes, so what do you all suggest? So far the truck is entirely stock.
Old Apr 21, 2014 | 05:05 PM
  #35
LSO1123's Avatar
LSO1123
That's a bunch of garbage. A 4" exhaust will be just fine. Most folks go with at least a 4" and some do 5".
Old Apr 22, 2014 | 01:20 PM
  #36
snowdog79's Avatar
snowdog79
I have a Banks 3" before the muffler and 4" out that works great. Mine has the 3" DP and the fuel turned up. Great power, not much noise.
Old May 21, 2014 | 02:59 PM
  #37
Pork_Chop50's Avatar
Pork_Chop50
Originally Posted by KrautBurner
so,
I see the date has this message as nearly a year old, but I wanted to respond anyway. In October of 2013 I bought and installed that exact downpipe and it is a straight bolt on. I used a long punch to fold my firewall weld lip away from the pipe because it looked like the two made slight contact and I wanted to eliminate possible vibration. Not much, maybe 1/4" of clearance. I also reused the factory heat shield and re-wrapped the Banks downpipe. I'm happy with the results, dropped by cruising EGT's 50*, and I screwed down my wastegate rod enough to see 2 psi @ 55 mph with a peak of 8 psi under acceleration.
Nick9219
17
Sep 12, 2021 11:40 PM
BltFordTough
Nov 25, 2018 05:41 PM
eutecticpt
Dec 29, 2016 07:11 PM
Maccray38
Jan 25, 2015 10:41 AM
7.3 IDI Turbo Diesel
Jul 3, 2013 09:08 PM
