Sponsored by: Real Truck
transmission fluid changing question
Old Jan 7, 2008 | 10:09 AM
electraglide's Avatar
electraglide
I have a 99 F250 SD and i have 136000 miles on it. I bought the truck used and was wondering if i should cange the transmission fluid and filter since i dont know for sure if it has been changed. I heard that you should not change it after it gets on up there in miles.
Old Jan 7, 2008 | 10:14 AM
Pocket's Avatar
Pocket
Go ahead and change it. If the trans is going to die, it will do it regardless of fluid change.
Many people out there don't change the fluid or maintain the trans like they are supposed to. Then when the trans starts acting up they go ahead and flush it out hoping that will fix it. Trans dies anyway and that's how wives tales start.
Old Jan 7, 2008 | 11:22 AM
Izzy351's Avatar
Izzy351
Yep -- get it changed. There is an easy trans flush procedure here:
http://www.7point3.com/Writeups/TransFlush.aspx
And there is more than one way to skin this cat.
Old Jan 7, 2008 | 01:58 PM
missouguy's Avatar
missouguy
I have used this method and it is quite simple. Couple hours work at the most.
Frank
Old Jan 7, 2008 | 04:38 PM
ken kenmnedy's Avatar
ken kenmnedy
YES YES get it flushed and change the filter that way you know what you have got. I did mine.now as I gas it up when its in overdrive it holds on just a little longer and only slips a little in 2nd gear.got the truck from the repo lot they got it from a body shop, so it was probly stolen and whiped but I can live with this!!!
Old Jan 7, 2008 | 06:39 PM
Citypol86's Avatar
Citypol86
This is for the 4R100. Is there a different procedure for the 5R110W? Is the theory the same for ANY trans?
Old Jan 7, 2008 | 09:09 PM
salesman112's Avatar
salesman112
I Have 74k And Recently Flushed My Tranny And Changed In Line Filter Not The Internal Filter(recommended By Ford Every Other Tranny Flush Which Should Occur At 60k Intervals) I Am Very Pleased With The Flush And Notice Tranny Down Shifting Less When Going Up Hills.
Old Jan 13, 2008 | 06:57 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The theory is the same for almost any trans. Some need some special steps added, and the TorqShift (5R110w) is one of those transmissions that need a change.
The TorqShift has a thermostat. When the trans is below about 165F it only sends 10% of the normal flow to the coolers. 90% is sent back into the trans. If you don't heat the trans well about 165F AND heat the new fluid that goes in you'll just mix the old and new and change only some of the old fluid and a lot of the new fluid.
That procedure is also here at FTE. https://www.ford-trucks.com/article/...nsmission.html lI've used this procedure on a lot of different cars and trucks. The trick is in knowing what's different about each different trans.
Old Jan 13, 2008 | 09:11 AM
Citypol86's Avatar
Citypol86
Thanks, Mark! That's what I wanted to know.
Later...
Brewster...
