Priming oil pump
Old Jan 7, 2008 | 09:31 AM
jam460's Avatar
jam460
Priming oil pump
I am finishing a mild build on an 85 F-250 with a 460. I'm using my 19.2V cordless drill running counterclockwise to prime my new Melling oil pump. I have oil slowly coming from the rockers on one side, but nothing on the other. I think my cordless won't run fast enough to move oil thru both sides. I plan to try at higher rpm with a corded drill tonight. Any thoughts would be appreciated.
Old Jan 7, 2008 | 10:47 AM
paulsrx700's Avatar
paulsrx700
What your doing is correct. When the engine is fully primed it turns hard.
Old Jan 7, 2008 | 07:57 PM
greenhighboy's Avatar
greenhighboy
Turn the engine over buy hand a few times and prime some more with a stronger drill and you should get oil from the other side.
Old Jan 8, 2008 | 06:48 AM
jam460's Avatar
jam460
Didn't get a chance last night but will try that tonight,thanks for the input.
Old Jan 8, 2008 | 06:35 PM
jam460's Avatar
jam460
I tried priming with the electric drill, turned motor over by hand several times and ran drill for several minutes each time. Still no oil coming from rockers on the one side. In the lifter valley are two 1/4" npt holes, I was told those do not get plugged when running hydraulic lifters. It sure seems like they would eat a lot of oil. Could this be the problem?
Old Jan 8, 2008 | 07:54 PM
mark a.'s Avatar
mark a.
Those plugs have to be in there.
Old Jan 9, 2008 | 09:31 AM
jam460's Avatar
jam460
Are those plugs ever left out or orifices put in the plugs?
Old Jan 9, 2008 | 11:23 AM
cobraguy's Avatar
cobraguy
I've never heard of leaving out oil galley plugs on purpose. I have seen some applications with orfices for oiling the timing chain. These usually squirt oil on the cam gear and centrifugal force slings oil on the timing chain.
Old Jan 11, 2008 | 10:51 AM
jam460's Avatar
jam460
Put the plugs in, I've got oil now. Thanks
IronHorseDriver
1983 - 2012 Ranger & B-Series
Oct 2, 2015 12:01 AM
four-sixty-power
Apr 14, 2014 04:44 PM
bikerbobby
1978 - 1996 Big Bronco
Aug 9, 2013 11:33 AM
MikeGV
Aug 14, 2004 01:48 AM
onewaymike
Nov 30, 2002 02:02 PM
