power steering conversion
Old Jan 4, 2008 | 05:41 PM
76fordo's Avatar
76fordo
I drive a 1976 f250 highboy 4x4 with the factory armstrong steering. I'm just wondering if anyone out there knows if there is some sort of a conversion to go from the armstrong to a full integrated power steering setup.
Thanks
Old Jan 4, 2008 | 06:07 PM
Mil1ion's Avatar
Mil1ion
There is a tech article in the FTE articles section..Under .....steering
Old Jan 4, 2008 | 06:11 PM
tylstruck's Avatar
tylstruck
Would be cheaper to find a parts truck. One that has ps and the same engine as yours.
I would think your parts truck would preferably be an F250 or F350. The steering linkage on a half ton truck would be too weak for your truck.
You would need;
-steering column
-steering box
-steering pump with hoses
-pitman arm with steering linkage
Tyl
Old Jan 4, 2008 | 06:13 PM
76fordo's Avatar
76fordo
Its going to be hard to find a parts truck because my truck has a 460 and is 4wd. In the 70's 4wd trucks never came with 460's. All im looking for is a bracket of some sort to bolt the steering box to my frame. I have all the other ****.
Old Jan 4, 2008 | 06:17 PM
76fordo's Avatar
76fordo
Also in 76 it wasnt a fully integrated power steering setup it was a power ram assist steering. I can't find any parts for that setup or else i would run it because it would just bolt in place, thats why im going for this conversion setup because the parts are readily available.
Old Jan 4, 2008 | 07:11 PM
ozzy460's Avatar
ozzy460
call l&L ind, they make the power steering mount your looking for for 460 conversions
Old Jan 4, 2008 | 07:25 PM
76fordo's Avatar
76fordo
The powersteering box mount or the power steering pump mount because it really has nothing to do with the motor, the only thing that is affected by which motor it is. is the lenght of the hoses. Anyways does L&L have a website?
Im looking for the power steering box mount by the way.
Old Jan 4, 2008 | 07:37 PM
ozzy460's Avatar
ozzy460
i thought you were looking for the mount for the power steering pump for a 460. never seen a power steering box mount, i used one kit i found on ebay around $800 second i did i used all junkyard parts, 78 79 steering box, notched the frame
Old Jan 4, 2008 | 07:46 PM
armstrongfordtrucks's Avatar
armstrongfordtrucks
check my pic's in my gallery, I have a 79 F 350 box on mine.
ARMSTRONGFORDTRUCKS
Old Jan 4, 2008 | 07:50 PM
bucks77ford's Avatar
bucks77ford
I also have pics in my gallery using a 78 F250 4x4 box.
Old Mar 13, 2008 | 09:50 PM
kevinn4087's Avatar
kevinn4087
Has anyone here tried this kit?
http://www.carsteering.com/addtocart/1975_Ford/Pick-up_Truck/Kits_And_Performance_Parts/82-80019.html
I am building a 75 CC hi boy and would like to use all new parts.
Alcaeus
27
Oct 14, 2009 12:56 AM
Nod
1966 - 1977 Early Broncos
Jul 7, 2009 02:31 PM
lizardman1
Feb 11, 2008 04:15 AM
craighix
Mar 31, 2007 03:12 PM
Shorty 66
Nov 8, 2006 08:17 PM
