CA 530 remote starter -troubleshooting please??
Old Jan 4, 2008 | 02:04 PM
SteveVFX4's Avatar
SteveVFX4
oh, ok. Mine is 3.5 years old and looks like the one in the picture, so I guess I have the "older" one.
You could email Travis too and see if he has any tips?
Old Jan 4, 2008 | 02:35 PM
YOMAN's Avatar
YOMAN
I did and am waiting for his reply, i know hes busy.
YOMAN!
Old Jan 4, 2008 | 03:14 PM
black04lariat's Avatar
black04lariat
Originally Posted by SteveVFX4
^black04, there is no "hidden key" in the box with his setup. He has the programable PATS bypass antenna, you program it with your two master keys and it "acts" like a key is there when you remote start it. Cold weather is known to effect the bypass antenna if it's not properly taped around the ignition cylinder.
Thanks for clarifying. As for future reference though, some brands/models, like mine use a "hidden key" along with an antenna around the cylinder. It basically a universal bypass and can be used on most any car that has a chip in the key.
Old Jan 4, 2008 | 03:28 PM
SteveVFX4's Avatar
SteveVFX4
oh I see. I never liked the idea of having a hidden key in my truck so I always bought the programmable antenna bypass for my past few installs.
Old Jan 5, 2008 | 11:52 AM
YOMAN's Avatar
YOMAN
UPDATED:
Travis from KCautosounds, we talked, he think bypass item is shot after tried reprogram keys and is sending me NEW one with no charge. I m happy with his business! great customer service!
He said its new update (improved) antenne ring for igintion area.
Later!
YOMAN!
Old Jan 5, 2008 | 12:45 PM
SteveVFX4's Avatar
SteveVFX4
That's good to hear he's taking care of you.
Old Jan 5, 2008 | 04:25 PM
Buck 1's Avatar
Buck 1
I have the Crimestoppers unit and the cold weather does not affect it; two days ago it was 0 here and it started with no problem.
Old Jan 5, 2008 | 07:22 PM
Ford Fx4's Avatar
Ford Fx4
Originally Posted by YOMAN
UPDATED:
Later!
YOMAN!
Yoman,
Good to hear, I just got off the phone with Travis myself and he is sending me a new brain out at no charge. He said the some times the tach signal is so low that the unit does not pick it up, basically the brain is just jacked up, When I talked to Code alarm customer service they also send this could be the problem. So he is sending out a new brain on Monday and should get it by Wednesday of next week.
Old Jan 5, 2008 | 08:15 PM
Patatoe1's Avatar
Patatoe1
Hey Yoman and Ford Fx4, I know that Travis is a good guy to deal with. It seems as if you both have installed the starters yourselves.
With limited electrical knowledge, how easy would you rate installing the remote starter following Travis' directions and with it pre wired?
Old Jan 5, 2008 | 08:43 PM
Ford Fx4's Avatar
Ford Fx4
Patatoe1, check out this thread as I just answered a bunch of questions for littlewille.
https://www.ford-trucks.com/forums/6...ggestions.html
On a scale on 1 to 10 I'd give it a 6, following the directions as he gives you pictures of were all the wires go.
Old Jan 6, 2008 | 10:24 AM
YOMAN's Avatar
YOMAN
I would say #5.
Its just wiring cut, snap, etc.
If I were you, do the hunt for wires colors first all of it (pull wire out of twist wires) like prepare it
Most important is to read the instruction 2-3 times and look around your truck under steering, take your time! Before you start..
I ran into problem that it didn't start and called travis we couldn't figure out until he realized that the brain need to be ground lol and it works! It was on sunday evening.
It took me about 4 hrs with breaks, read again.
It was my first time and did a well!
Good luck
Old Jan 6, 2008 | 02:40 PM
Patatoe1's Avatar
Patatoe1
Thanks to both you guys.
Old Jan 19, 2008 | 05:00 PM
  #28
YOMAN's Avatar
YOMAN
Updated!
Just got the bypass module by KCautosounds (Travis) it was new one as updated as better than old one.
I removed old bypass box and installed new one and its all back to normal!!
The new one has NO antenna cuz its wiring directly to factory ring PATS! its cool.
I want to big thank Travis for sent me a free replace bypass module!
YOMAN!
2011FX2Crazy
2009 - 2014 F150
Oct 7, 2020 05:20 PM
stevef22
Feb 6, 2017 10:51 PM
DallasSuperCrew
2004 - 2008 F150
May 30, 2016 09:13 PM
FordTruckChuck
1997 - 2003 F150
Sep 29, 2015 05:53 PM
FordLover57032
1997 - 2003 F150
Aug 21, 2015 12:21 PM
