99 just quit
Old Jan 9, 2008 | 06:44 PM
ron's power stroke's Avatar
ron's power stroke
how long has fuel filter been in there?? how cold id it where you are??
Old Jan 9, 2008 | 06:51 PM
zx250's Avatar
zx250
Of the next Riffraff East
Sounds like you have a bad fuel pump or fuel pump relay.
Old Jan 9, 2008 | 06:53 PM
PaysonPSD's Avatar
PaysonPSD
If it won't rev beyond 800 rpms which is just a hair over idle speed this may point to the Throttle Position Sensor.
Old Jan 9, 2008 | 07:24 PM
dawg 21's Avatar
dawg 21
fuel filter has been in for about 8500 miles the temp here has been warm in the 40's today 60's past few days
Old Jan 9, 2008 | 07:31 PM
dawg 21's Avatar
dawg 21
I may go up to 900 or 950 not over 1000 though
wouldn't it diplay a code for the tps being bad??
Old Jan 9, 2008 | 07:40 PM
dawg 21's Avatar
dawg 21
whats the best way to test the relay would a test light work?
Old Jan 9, 2008 | 07:41 PM
PaysonPSD's Avatar
PaysonPSD
I really don't know. Someone else will.
Old Jan 9, 2008 | 07:43 PM
PaysonPSD's Avatar
PaysonPSD
I really don't know. Someone else will. It is, at least, coming off idle.
OOPS Double Post.
Got one of these during first post:
<DIR>There seems to have been a slight problem with the database.
Please try again by pressing the refresh button in your browser.
An E-Mail has been dispatched to our Technical Staff.
We apologise for any inconvenience.
</DIR>
Old Jan 9, 2008 | 08:02 PM
F350-6's Avatar
F350-6
Is this a KOEO or KOER code?
Continuous DTC P0232 indicates that power was present on the fuel pump monitor circuit when the fuel pump was commanded off during normal driving conditions.
I'd first check to make sure you got the new CPS plugged in good. Then remove the fuel filter lid and see if it's full. Drain it down and make sure it fills back up by cycling the key, and checking for a good steady stream of fuel with the key on and the drain valve open.
Old Jan 9, 2008 | 08:16 PM
zx250's Avatar
zx250
After looking at the manual, I don't even know if it has a fuel pump relay. A fuel pressure gauge would tell you if your pump is up to par. Go with Chris's thoughts first and post back.
Old Jan 10, 2008 | 04:42 AM
ron's power stroke
i would also change out that fuel filter..it may have wax build up in it keeping fuel from going to the injectors..also good idea to check fuel pressure as Chris said in post #24
Old Jan 14, 2008 | 07:10 PM
dawg 21's Avatar
dawg 21
Just a quick thanks for all the help guys I put a new fuel pump in the truck is running great thanks again Dave
Old Jan 14, 2008 | 08:05 PM
  #28
zx250's Avatar
zx250
Glad you got her fixed. Just curious, how many miles do you have on your truck?
Old Jan 23, 2008 | 12:25 PM
  #29
dawg 21's Avatar
dawg 21
169,700 miles
Mikegenuine
52
Oct 15, 2016 05:40 PM
dawg 21
17
Nov 19, 2008 08:48 PM
dawg 21
Feb 10, 2008 03:15 PM
rosa70
Jul 10, 2007 05:19 PM
jnye6625
20
Mar 7, 2007 02:51 PM
