truck quit
truck quit
I Have A 99 F350 It Quit The Other Day It Wouldn't Start The Guy That Works For Me Was Pulling Me Home I Put It In Gear Poped The Clutch And It Started Right Up Has This Happened To Any Of You Guys It Turns Over Fine It Just Would Not Run I Checked For Codes And 1211 Came Up
Thanks Dave
Thanks Dave
How well did it crank? Low battery voltage can be a killer, and marginal batteries would cause the voltage to be too low for the PCM to fire the injectors while cranking. At the same time, a pull start would keep the voltage high enough to fire the injectors by not running the starter. That would be the first thing I checked.
