99 psd quit
Old Nov 11, 2008 | 06:15 PM
dawg 21's Avatar
dawg 21
99 psd quit
Driving to work this morning my 99 350 with a 7.3 and 6 speed quit in a traffic jam this morning got it pushed off the road (heavy truck) my buddy came to the rescue he checked for any codes and there was none he started pulling me with his truck so I put it in gear and dropped the clutch it fired up had no power and smoked (blue smoke) so I held it to the floor and it cleared up and ran fine after that but we went to the dealer and picked up a cps and changed it out I was wondering if you guys think he fixed the problem??
Thanks Dave
truck has 175500 miles it had the new cps I changed it in last winter
Old Nov 11, 2008 | 06:27 PM
F350-6's Avatar
F350-6
I haven't heard of the CPS causing smoke like that before.
Blue or blue/white smoke:
Caused by insufficient fuel or oil consumption. Normal when engine is cold or idling for extended periods.
Excessive smoke could be caused by air in the fuel, contaminated fuel, loose or plugged injectors, worn or leaking injector o-rings, thermostat stuck open, oil consumption, or plugged crankcase depression regulator valve. Also PCM inputs such as MAP or ICP sensors.
Engine oil full? Air & fuel filters clean? Any of the above sound like a possibility?
Old Nov 11, 2008 | 06:34 PM
dawg 21's Avatar
dawg 21
changed the oil last night and its full changed the fuel filter today my buddy had one on his service truck so he out it on and it still wouldn't start the engine was not cold as the truck was driven about 9 miles this morning before it quit
the smoke was more like blue/white
Old Nov 11, 2008 | 06:42 PM
F350-6's Avatar
F350-6
How dirty was the old fuel filter? What did your buddy use to pull the codes? Was the check engine light on? Not all scanners can read our codes.
Old Nov 11, 2008 | 06:55 PM
dawg 21's Avatar
dawg 21
I don't know what brand of scaner he has the filter didn't look to bad to be the check engine light did not come on
Old Nov 11, 2008 | 07:52 PM
F350-6's Avatar
F350-6
Is the oil still full? What oil did you use, and how much did you put in? I'm not saying this is oil related, but you changed the oil then this showed up, so it's something to consider.
When is the last time you filled up with fuel? Any possibility of bad fuel? Have you driven it any since the ride home? Any symptoms re-appearing?
Old Nov 11, 2008 | 07:59 PM
dawg 21's Avatar
dawg 21
i used the same oil I always use shell rotela 15 40 and its full I drove the truck about 45 miles since it quit and it runs ok
When the truck refired and was smoking like a train there was not much combusion kock then as it cleared up the knock came back
Old Nov 11, 2008 | 08:15 PM
rbaker6336's Avatar
rbaker6336
could tin nut be off of IPR or maybe bad ICP sensor
Old Nov 11, 2008 | 08:30 PM
F350-6's Avatar
F350-6
If it stalls again, and it's safe to do so, quickly turn the key off and check the fuel level in the fuel filter bowl to make sure your pump isn't cutting out on you.
Good call on the tin nut Ray. Check to make sure that thing's not loose and causing your problems. If you get another no start condition, you can test the ICP by just unplugging it and trying to start. You can test the MAP sensor the same way.
Old Nov 11, 2008 | 08:38 PM
dawg 21's Avatar
dawg 21
whats a ipr ?
Old Nov 11, 2008 | 08:48 PM
F350-6's Avatar
F350-6
Originally Posted by dawg 21
whats a ipr ?
Injection Pressure Regulator. It controls what pressure oil the injectors see to fire. If it opens all the way up, you get no oil pressure to the injectors and the truck dies. It's on the back side of the HPOP reservoir on the drivers side.
Here's a picture I borrowed from Barry. The IPR is about the 2 o'clock position on the fuel filter bowl.
Old Nov 11, 2008 | 08:53 PM
dawg 21's Avatar
dawg 21
nice picture my engine is not that clean
Old Nov 11, 2008 | 08:55 PM
F350-6's Avatar
F350-6
Neither is mine. That's why I posted a picture from Barry. All my parts are camouflaged in a nice coating of dirt.
Old Nov 11, 2008 | 09:46 PM
schlepprock250's Avatar
schlepprock250
Smoke caused by the thermostat being stuck open??!
Old Nov 12, 2008 | 06:05 AM
F350-6's Avatar
F350-6
Think light white smoke like when the truck is first started on a cold morning and the engine isn't warmed up yet. The factory dummy temp gauge will help determine if this is it. I don't think that's the case here, but thought I would list it anyway.
