99 just quit
Old Jan 2, 2008 | 07:08 PM
dawg 21's Avatar
dawg 21
99 just quit
hey guy's i've got a 99 f350 with a psd it just quit running the other day on my way to work had to tow it home I've just pulled the codes the codes that I pulled out were p0541, po232, and po340 i was talking to a friend of mine he was thinking a cps but i put a new one in about year ago then the cps went last year the truck would always start but this time nothing what do you guys think
would the cps throw more than 1 code??
thanks for your help Dave
Old Jan 2, 2008 | 07:26 PM
PETE'S_6.0PSD's Avatar
PETE'S_6.0PSD
well check the Fuel bowl heater , this is common failure , check i think fuse # 30 if its blown Unplug fuel bowl heating element, thats the plug bu the drain Valve in the back of the fuel bowl. and than replace the fuse.
do you get WTS light when you turn the key? and does it turn over or not?
Old Jan 3, 2008 | 05:02 PM
dawg 21's Avatar
dawg 21
i checked the fuse its good the wts light seems to cycle like it always has it turns over fine just doesn't start do you think i should put in a new cps?? i can save the other one for a spare if its not the problem??
Old Jan 3, 2008 | 05:14 PM
lancer's Avatar
lancer
If all fuses are fine i would try the cps next.
Old Jan 3, 2008 | 05:15 PM
dawg 21's Avatar
dawg 21
i forgot the check engine light is not on
Old Jan 3, 2008 | 05:20 PM
1996pwrstrk's Avatar
1996pwrstrk
Is the tach moving when you turn it over and do you have any smoke ?
Old Jan 3, 2008 | 05:31 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Change the CPS again. That 340 code is the CPS. Theyre only $20 or so now.
zx250's Avatar
zx250
Of the next Riffraff East
P0232 Fuel Pump Relay Dvr Circuit Fail Off
Not sure on this, Check your fuel shutoff on the passenger side under dash.
P0340 Camshaft Position Sensor Circuit Error (bank1/1 Sensor)
Sounds like a CPS
P0541 Manf Intake Air Heater Circuit Low
This comes from the AIH delete mod. not a problem.
Old Jan 3, 2008 | 05:37 PM
dawg 21's Avatar
dawg 21
i will check that out after dinner i'm guessiing that i'm looking for white smoke??
Old Jan 3, 2008 | 06:12 PM
dawg 21's Avatar
dawg 21
the tact does not move when you turn it over i did not notice any smoke is that good or bad??
Old Jan 3, 2008 | 06:16 PM
zx250's Avatar
zx250
No tach usually means bad CPS. Get your a $25 one from Ford and start there, clear your codes and see if any comes back.
Old Jan 3, 2008 | 06:17 PM
dawg 21's Avatar
dawg 21
Sounds like a CPS
i checked the shut off it appears to be set
thanks for the help
Old Jan 3, 2008 | 06:22 PM
dawg 21's Avatar
dawg 21
thats what i will do thanks for all the help guys
Old Jan 3, 2008 | 06:28 PM
zx250's Avatar
zx250
Yeah, the worse you could do if that's not it is have a spare.
Old Jan 9, 2008 | 06:36 PM
dawg 21's Avatar
dawg 21
ok i have installed the new cps now the truck starts won't rev past 800 rpm's cleared the codes the only code I have now is p0232 could this be a bad fuel pump??
