tempature sensor
Old Jan 1, 2008 | 03:21 PM
razor's Avatar
razor
Question tempature sensor
was putting on new belt noticed sensor was broke where plastic meets brass so pulled it off since was i was there put new one in now doesnt work any ideas ?
Old Jan 1, 2008 | 03:58 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Can you be more specific, what doesn't work? What sensor is it if you know, and can you give a more detailed description of where the sensor is?
Old Jan 1, 2008 | 07:08 PM
razor's Avatar
razor
its the temp sensor screws into water pump it had thread tape when removed but didnt have any when replaced so not got none now if that helps
Old Jan 1, 2008 | 07:09 PM
razor's Avatar
razor
its the temp guage in truck that doesnt work
Old Jan 1, 2008 | 07:55 PM
Tenn01PSD350's Avatar
Tenn01PSD350
How long has the gauge been inop and was it a factory or aftermarket sensor replacement?
Old Jan 2, 2008 | 07:57 AM
cleatus12r's Avatar
cleatus12r
Butt-Head
Yes, the temperature sender that screws into the top of the water pump near the thermostat housing (upper radiator hose outlet) is for the temperature gauge.
Old Jan 2, 2008 | 09:22 AM
Izzy351's Avatar
Izzy351
My truck's temp gauge didn't work when I bought it. Made the dealer fix it, but the service report said "replaced sender & thermostat". I bought the truck in January, and it took forever to get heat. If you have that problem, you might check the 'stat, too. If it's stuck open, the large cooling system will keep the engine from warming up much (especially in winter!).
Today it was about 23* when I left the house. Now, my truck is garage kept, but I still let it sit in the driveway for about 5-10 mins to warm up. EBPV closed, and by the time I got in and started on the way, I already had some heat.
Old Jan 2, 2008 | 05:00 PM
razor's Avatar
razor
dont think its thermostat it was 18 here this morning and i always warm it up about 15 mins and has great heat so ill try new sensor maybe got bad one also should i unhook batteries to reset anything thanks charlie
BlueOvalJunkie11
Jul 7, 2013 03:28 PM
Robyone
Jun 21, 2011 01:31 PM
rocknrotty
Dec 22, 2009 11:48 AM
shawnk18
Jan 10, 2007 08:56 AM
motocam25
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
21
Jan 5, 2005 09:39 AM
