I put new tires on my 06 EB last month and turns out my TPS was bad as well. Firestone said they could replace it for $150 if memory serves me correctly, but I told them no thanks. I have to live with a "Low Tire Pressure" warning everytime I start up my car, and a low tire pressure dummy light all the time, but I'm fine with the saving the $$$ right now.
I'm in the same boat. Dealer told me the passenger front is bad ($250). so i push the button each time I start it. I tried to see if I could yank a fuse, but got bored trying to find it and I'm sure there is something else in with it. The most irritating part is that mine is intermittant so I could be driving down the road and all of the sudden the chime goes off. I can post the learning info again if you want to make sure it is programmed - but if they just changed the tires, it should not have effected it. Thanks, Mike.
If it wasn't a problem before the tire change, the shop probably damaged the sensor removing or installing the tires. Getting them to admit to it is a tough sell.
that is exactly what happened I see it all the time
