Downpipe Removal
Old Jan 1, 2008 | 11:04 AM
scatgo's Avatar
scatgo
Downpipe Removal
I had to disconect my down pipe at both ends to remove my turbo and noticed its a pretty tight fit. I wanted to push it down to get it at of the way but that would not happen. Since I was abel to get it far enough out of the way I didnt realy look into it. I just orderd a down pipe and I am going to have to remove it.
Am I going to have to breake out the sawsall to get it out? Would that be the easyest way to get it out? I would rather not cut it unless I have to. The pipe I orderd is a two piece so going in should be easyer. I noticed a lot of people wrap there pipes. I guess this is to keep under hood temps down but what dose it do to turbo and engin temps? http://dieselperformanceparts.com/fordalum1.html
Old Jan 1, 2008 | 11:24 AM
Epd444's Avatar
Epd444
Yea i think your def gonna have to break out the sawzall, it's probably the easiest way to get it out. I'm not sure on the wrapping part I didnt wrap mine
Old Jan 1, 2008 | 11:31 AM
Neal 97 250's Avatar
Neal 97 250
I pulled mine in one piece BUT... I had the trans and trans case removed and tiltede the engine so far back I thought it would break the motor mounts and then I still had to beat it out. Do yourself a favor just cut it.
Old Jan 1, 2008 | 12:16 PM
scatgo's Avatar
scatgo
Thanks. Just saw a post by coon about wraping the pipe. Lots of info there..
Old Jan 1, 2008 | 01:55 PM
IceboxFX's Avatar
IceboxFX
yeah your gonna have to cut it. i used a plasma torch to get mine out, but a sawzall with do just fine. your gonna want to bend the firewall back so the downpipe does not rub against it. i didnt bend mine enough and my truck rattles alot when i'm turning or going up a steep incline.
Old Jan 2, 2008 | 12:28 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
Scatgo, this link if for you.
http://www.drivetrain.com/downpipeinstinstr.html
I bought a DP ceramic coated so I dont needed any wrap
Old Jan 2, 2008 | 12:31 PM
tjbeggs's Avatar
tjbeggs
That is the best way to go! much better heat shield and can't trap any moisture!
RAMPAGE_F350
Mar 30, 2008 08:29 PM
FordF350Baby
Exhaust Systems
32
Aug 27, 2007 09:52 AM
Jay-re
May 16, 2007 09:13 AM
John311t
39
Dec 19, 2006 07:53 PM
goofynick6
Modular V10 (6.8l)
Jun 6, 2004 10:10 AM
