To Much Blow By
Old Jan 7, 2008 | 05:25 PM
  #31
cchildress's Avatar
cchildress
Ya about the studs I was looking at the A1's and I was looking at the powerstrokeshop over hall kit, I think it comes with just about everything. And the block Im guna send off and have all the bearings put in it and cylinder walls done and pistons put in and then have the bottom end balanced bc they arent balanced from the factory.
Old Jan 7, 2008 | 05:38 PM
  #32
MADVAN's Avatar
MADVAN
Originally Posted by cchildress
I have talked to a lot of people and no one has ever heard of blowing a hole in a piston. Il post pics when I can. Im not sure what caused this. To much heat is the only thing that would come to mind but I only have stock sticks. What all do yall think I should on the rebuild?
DP-120hp with no intercooler or water inj.
How does the turbo (exhaust side wheel) look?
Just wonder with your washer pump mod.
https://www.ford-trucks.com/forums/6...eap-smoke.html
Bill
Old Jan 7, 2008 | 07:07 PM
  #33
cchildress's Avatar
cchildress
Still nothing bc I have stock sticks and not enough fuel to even worry about heat. With any tune for these injectors they will not ever creat enough heat to produce damage. The washer pump would do nothing either. The exhaust only goes one way and never the other. I checked the turbo and no play or damage I never looked at the exhaust side. The only thing that scares me is where did that piece of the piston go. It may be in the oil pan.
Old Jan 8, 2008 | 06:38 AM
  #34
MADVAN's Avatar
MADVAN
Not true it can and will.
Also not true. Exhaust has neg pulses.
Pull the house off to get a good look at the wheel.
How much boost was the motor making?
On a WAG. I would look into the nozzles and nozzle springs before you install your inj back into the new motor.
Bill
Old Jan 8, 2008 | 06:28 PM
  #35
cchildress's Avatar
cchildress
With my littler tires would spool around 25 but on average about 15 at the most with the bigger tires. Im guna send the injector off to jim and have him rebuild them bc the tips dont look good. What rebuild kits do yall recommend for the rebuild.
Old Jan 8, 2008 | 06:43 PM
  #36
tjbeggs's Avatar
tjbeggs
Powerstrokeshop.com has good prices on the kits but wait till your machine shop says if it needs bored or not. It will make a difference on which kit you buy. Also get the kit to machinist before they start any machining as the cylinders need to be machined to the pistons.
Old Jan 9, 2008 | 12:18 AM
  #37
cchildress's Avatar
cchildress
I looked at the website and never saw a kit for the over haul for the engine. Do you have to call?
Old Jan 9, 2008 | 07:49 AM
  #38
tjbeggs's Avatar
tjbeggs
Yeah I just looked. They must have taken them off the website. I guess you do need to call. They were just over $900 for a complete overhual kit.
Old Jan 9, 2008 | 07:10 PM
  #39
cchildress's Avatar
cchildress
I called today and they did not answer so I left a message. What would be a good fuel system to put on the truck thats not way out there on price.
McQ
15
Jun 17, 2012 08:33 AM
snowyrangediesel
Mar 9, 2011 06:28 PM
hiredgun18
26
Sep 24, 2010 09:37 AM
jeepinkerr78
1997 - 2003 F150
Jul 16, 2010 07:55 AM
jpounders
Oct 14, 2007 08:41 AM
