E4OD overdrive shift problem
Old Dec 31, 2007 | 06:04 PM
Nitronic's Avatar
Nitronic
So here's the story, I went offroading about 3 weeks ago and got stuck in a huge hole, half of the truck was sunk. I know, stupid. The transmission oil got water in it so I changed all the fluids and took it for a test drive and it is not shifting into 4th, it shifts from 1st to 2nd fine, and sometimes shifts to 3rd. The transmission oil is clean and full.
So the question is, judgeing on my situation, am I ****ed out of a thousand on a rebuild or could it be the solenoid that got wet or something?
Thank you for your time
Old Dec 31, 2007 | 06:08 PM
danr1's Avatar
danr1
Did you check to see if it has any codes?
Old Dec 31, 2007 | 06:17 PM
Nitronic's Avatar
Nitronic
Nah no codes.
Old Dec 31, 2007 | 06:22 PM
danr1's Avatar
danr1
Did you change the filter when you changed the fluid?
Old Dec 31, 2007 | 06:43 PM
Nitronic's Avatar
Nitronic
Of course.
Old Dec 31, 2007 | 07:07 PM
danr1's Avatar
danr1
Originally Posted by Nitronic
Of course.
Hey someone had to ask!
If it was something in the solenoid pack I would think you'd be getting some kind of code for it.
Ok the service manual says, (what could pertain to what you did, "muddy water").
No drive in Drive range,
Inspect pump control body and valve body-Dirty or sticky valves.
I got a better way just a minute….
Old Dec 31, 2007 | 07:39 PM
danr1's Avatar
danr1
Here is what the service manual for the E4OD says,
<br><br>,<br><br><br><br>
Some of it is a repeat, (I didn’t write the book) but I wanted to make sure you had it all.
But that gives you “no drive” and “no 3-4 up shift”, I’ll see if more pertains to your issue.
Tell me how it does shift in the gears that work and when it does shift to drive, a lot of what it says to do depends on that.
Old Dec 31, 2007 | 08:27 PM
mhg's Avatar
mhg
stuck and water
MLPS
maybe a bad ground
www.fordfuelinjection.com
goto download files
there is a right up about e4od
Old Dec 31, 2007 | 09:42 PM
86caprirs's Avatar
86caprirs
So after it got stuck,did you shut the truck off and tow it home?Or did you drive it home and it still had OD.Did this no 3-4 shift happen after you performed the trans service?I am not sure about the E4OD,but I do know that the A4LD had a huge problem of breaking the OD band.The A4LD are not the same as the E4OD but if it does not shift into 4th, you could try performing the band adjustment.Lossen the nut and tighten the stud to 10 foot pounds.Then back the stud off 1 turn and sinch the locking nut.
The other thing is you may have a tiny pice of sand in the solinoid causing it not to opperate leaving you stuck in 3rd.
Remember the valves in the valve body are precise fit.If water was to get in there and contaminate the valve body,then you could have an issue there.
Let us know what you find.
Old Jan 1, 2008 | 06:28 PM
Nitronic's Avatar
Nitronic
Thank you for the responces, I am going to blow off the solenoid and see if that does anything.
86caprirs - The truck idled for a few hours in the water
Old Jan 3, 2008 | 11:27 AM
Nitronic's Avatar
Nitronic
Turned out to be two blown shift solenoids, fixed and it shifts fine. Thank you for the responses.
Old Jan 3, 2008 | 04:55 PM
fmr9's Avatar
fmr9
For future reference, could you explain how you did the trouble shooting, and tested the solinoids?
Thanks Frank
oldtruck36
76
Apr 16, 2024 01:26 PM
cajunron
16
Jun 12, 2016 05:39 PM
Bartsteltzer
Mar 19, 2016 11:43 PM
used2jeep
Jul 22, 2015 09:54 PM
Prototypemech
Dec 24, 2013 10:05 PM
