E4OD Transmission Shift
Old Mar 19, 2016 | 11:23 PM
Bartsteltzer's Avatar
Bartsteltzer
4wd Low
So I am new to this forum and I just bought a 97 powerstroke with an E4OD automatic transmission. When I first got it it would have a pretty aggressive up shift into 3rd. I did some research on other forums and found that issue was usually from the accumulator body springs being bad. So I ordered a rebuild kit from monster transmission and installed it earlier this afternoon, changed the oil and used Mercon oil, and changed the filter. Now when I drive it it I have all the gears but it won't shift to 2nd unless you let off the throttle then shifts to 3rd and 4th way quick. Does anyone have any ideas on what it could possibly be? I have double checked the oil and it is at the proper level. Any advice will be appreciated!
Old Mar 19, 2016 | 11:43 PM
I am Murphy law's Avatar
I am Murphy law
Brothe i have got the same issue with the 2000 model that I just bought and it's got the 4r100 transmission in it drove it ran fine stop putting part was the island for a few minutes but back and drive and start slipping in first second Drive Overdrive but the reverse was strong as all get-out
Daryl4
Sep 4, 2017 02:31 AM
ml8on
1978 - 1996 Big Bronco
15
Apr 23, 2014 11:58 AM
IDIDieselJohn
Feb 6, 2014 10:14 AM
AggiePSD
Jan 8, 2003 10:53 AM
