What size Engine stand to use?
Old Dec 22, 2007 | 05:04 PM
sdetweil's Avatar
sdetweil
Not high temp. We couldn't find anything close to the body color in high temp.. but I talked to a number of engine builders that said it should be no problem as long as there was a good primer under it.
Same was done on Trucks for the Copperhead truck.
Its thick too.. 2 primer, 3 base, 4 candy, 2 clear. there IS an engine under there somewhere..
the engine had been baked clean prior to the bore job, and same with the heads.. so it was real clean.. and we cleaned it more before the primer.
we painted the timing cover and water pump separate and assembled, in case we had to take them back off so we wouldn't crack the paint.
tranny is the same color too..
Sam
gcooter
16
Mar 15, 2016 04:42 PM
crazy96863
Jan 26, 2016 11:51 PM
AbusedAmericanRust
Aug 16, 2015 03:08 PM
Sherbo
13
Apr 29, 2015 05:23 PM
OldWoodsDiesel
37
Nov 24, 2013 05:37 AM
