Icp
Old Dec 20, 2007 | 11:05 AM
caseydudem's Avatar
caseydudem
Icp
How often should you change you ICP? I am trying to trouble shot a idle problem. I would like to get a video on here for everyone to see, but I have never done that before. Is there a standard time that you should change the sensor?
Old Dec 20, 2007 | 11:24 AM
fuelman's Avatar
fuelman
I would think only if bad.Desribe problem,hot cold fresh oil, old oil,did you unplug icp to notice a difference.
Old Dec 20, 2007 | 11:30 AM
caseydudem's Avatar
caseydudem
To be honest I haven't had time to really look at it. I have just noiticed the systems while driving. The ICP is really dry around it but I have not unpluged it yet. The idle issue is the worest when cold but is noticeable when warmed up. Oil was just changed and I have checked the level and it is full. Also when I start it seems that the first cylinders fire and then a pause split second and the others fire then it runs normal well slightly rough but more normal.
Old Dec 21, 2007 | 12:05 AM
RubberDuck's Avatar
RubberDuck
That's the opposite of bad IPR orings. If the orings are bad, it will idle better cold and worse when hot. And you'll have a slow warm engine start.
Kiera Lacy
Jul 31, 2014 03:22 PM
mongo75
16
Dec 10, 2011 05:33 PM
wulfman
Feb 28, 2011 07:56 PM
bearhugger
May 20, 2010 12:34 PM
dpoelstra
May 16, 2003 02:38 AM
