ICP Voltage not consistant -suggestions?
Old Dec 8, 2011 | 01:28 PM
mongo75's Avatar
mongo75
My engine is running ok, but still not as smooth as I think it could be. I hooked up my Predator last night, and the ICP voltage is not consistant, and I'm guessing that this could be a reason for the rougher than normal running. Where should I start? Should I change the ICP sensor first? Not sure of what would effect the ICP other than the HPOP, and that's only a couple of years old. ANy ideas where to start looking to avoid throwing money at it -that I don't have LOL.
THanks!
Old Dec 8, 2011 | 02:00 PM
PaysonPSD's Avatar
PaysonPSD
Ohm the IPR solenoid. It should read somewhere between 10.2 and 10.8 ohms. The reading should be steady and not vary. If the reading fluctuates it can be the cause of rough running. If the solenoid holding nut is loose when you go to remove the solenoid that may well be the problem
The needle in the IPR may not be sliding smoothly which will also cause rough running.
If the IPR is not working properly then the PCM will see erratic ICP pressure and make erratic adjustments.
Old Dec 8, 2011 | 06:58 PM
F350-6's Avatar
F350-6
How much does it move around Danny? ICP pressure doesn't stay perfectly still either, and pressure and volts are related in the readings.
Old Dec 9, 2011 | 12:37 AM
mongo75's Avatar
mongo75
Late reply- was busy putting up the trash cans and helping daughter with math homework... anyways, tonight I took readings from my Predator, on both stck and 80E- here's what I got
Stock
rpm- 686-702
ICPv- 1.10-1.8v
Pulse width- 1.128- 1.84ms
80E
rpm- 654-692
ICPv- 1.10-1.9v
Pulse Width- 1.112- 1.240ms
SO thats the best I could come up with given they all keep changing. Anyone know how these numbers look?
So if you can see anything worng with pirctue
Old Dec 9, 2011 | 08:54 AM
01PS's Avatar
01PS
I've been dealing with the same thing for over a year now. Replaced ICP, ICP harness, IPR, CPS, etc. and it still runs rough. The ICP voltage looks like a square wave when I plot it in AE. I've been having another problem that I think I traced back to my APP sensor. Bought a new pedal assy that I'll install this weekend. I'll let you know if that fixes my fluctuations.
Old Dec 9, 2011 | 09:01 AM
dsquared's Avatar
dsquared
Danny:
I did some data logging in late October with the Predator. I've got the file at home, and I think it gave me a GANG of info I wasn't after. I'll try to post up numbers later today, give you something to compare against.
Old Dec 9, 2011 | 09:41 AM
mongo75's Avatar
mongo75
Hey guys I really appreciate everyone doing what they can to offer help and advice on this damned issue. Ultimately for me what it boils down to is that I just need a reliable truck that I know won't break down while I'm running a load of cars somewhere.
About 42,000 miles ago my block cracked out of the blue, in the middle of freaking nowhere on the 395 on my way to Reno to pick up a trailer. Between towing, the stealership, and me rebuilding the block it cost right about $4000. Still saved over $6000 by doing it myself.
Then while making a run to North Carolina with a load of cars I broke down in Las Cruces NM- 2 injector cups where leaking coolant into the oil. Had to sub out the run, lost that pay plus the idiot I hired damaged two of the 6 total cars, and between hotels and the stealership "doing it by the book only" (take off the cab, pull the heads), car rental for a week to get back to SoCal, that nightmare cost me about $3000.
I retire from the Corps in 2 years, and want to run full time in SoCal and can't afford, nor do I want a new truck with a warantee.
Old Dec 9, 2011 | 05:15 PM
mongo75's Avatar
mongo75
bump bump bump
Old Dec 9, 2011 | 05:33 PM
tdpower's Avatar
tdpower
Maybe contact dp tuner and see if it could be a tuning issue. It seems to be a little smoother in stock. How are your other tunes? Is this just a recent issue?
Old Dec 9, 2011 | 06:14 PM
dsquared's Avatar
dsquared
Danny:
Sorry! I just opened the file, and I didn't record pulse width or ICP Voltage. Just pressure, and duty cycle were what I was after...
If it will help, I'll check it in a while. Let me know!
Old Dec 9, 2011 | 07:29 PM
mongo75's Avatar
mongo75
I'm assuming your ohm it while it's running, or can you get desired results with it off?
Old Dec 9, 2011 | 07:31 PM
mongo75's Avatar
mongo75
Grant- I'd love to have it live tuned again, but I never know when Jody will be back out west again. I'd pay the $400 to get this damn thing running right.
Don, if you have a spare minute, I'd appreciate the help but don't go outta your way for this.
Old Dec 10, 2011 | 12:51 PM
dsquared's Avatar
dsquared
Danny:
Here's some numbers from this morning.
Stock - Started up...
rpm: 711-728
ICP v: 0.83 - 1.03
FPW: 2.648/2.728
Stock, Warmed up...
rpm: 666/688
ICPv: 0.68/0.86
FPW: 2.664/2.728
80e, warmed up....
rpm: 672/688
ICPv: 0.78/0.78
FPW: 2.664/2.744
Don't know if this will help you diagnose or not....But good luck to you Brother!!
Old Dec 10, 2011 | 02:03 PM
PaysonPSD's Avatar
PaysonPSD
Pull the solenoid off the IPR. That will allow you to check and clean the pins on the solenoid and the connector.
Old Dec 10, 2011 | 02:09 PM
woodnthings's Avatar
woodnthings
ICP will fluctuate as the engine is running. What are you seeing with the engine off? It should be stable there. Also the values will decrease as the engine warms up. First thing I would do is pull the ICP connector and look for oil on the contacts. If you see oil, replace the ICP sensor. The oil messes with the resistance and causes the PCM to hunt for the right pressure.
You say it is not running smooth. Is it at idle, or all RPM's? That makes a big difference to what you should be looking at. I switched over to an OEM black CPS and my idle became much smoother. Adding a Riffraff FRx also helped.
