ICP Question
Old May 19, 2010 | 09:46 AM
bearhugger's Avatar
bearhugger
ICP Question
OK guys,a while back there was a question about the icp, dont know if their was a conclusion,if you disconnect the icp and no change in how the motor runn,is icp bad or good.
Thanks Jim
Old May 19, 2010 | 11:04 AM
chicagodragon's Avatar
chicagodragon
i think if it is bad, the engine will run better disconnected.
Old May 19, 2010 | 12:01 PM
JamesHajek's Avatar
JamesHajek
If you disconnect something, the computer will go to a default preset situation. So if yours is bad, and you disconnect it, i think it should get better. If yours is good, there should be no change.
Old May 20, 2010 | 07:22 AM
ruger761's Avatar
ruger761
I just changed mine out. My truck wouldnt hardly run till it thew the coded and went to the preset value. Cleared the code which kills the truck then start it back up same thing wont hardly runs and dies. Unplug the CPS starts right up and runs great but with an auto trans shifts super hard. And thats an expensive little sensor. I paid $177 at dealer no one else had it intown. But even online most are $160s
Old May 20, 2010 | 10:58 AM
bearhugger's Avatar
bearhugger
Ruger761,you mean to say icp and not the cps ,didnt you.
thanks Jim
Old May 20, 2010 | 11:14 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Thanks Jim
I have read something similar but with the MAP sensor: if you disconnect and the motor runs BETTER, then you MAP is bad, and IF there are not a significant changes (just a CEL) IT IS fine.
In the other hand about the ICP I have read that when the truck dont start and you disconnect the sensor and it runs, the sensor is BAD
Old May 20, 2010 | 12:34 PM
ruger761's Avatar
ruger761
Yep i ment ICP had my head up *ss there for a moment
carbo12jim
Jan 15, 2014 03:23 PM
dvldog13
Aug 6, 2013 12:24 PM
Byrddog
Mar 18, 2012 04:23 PM
hammer65
20
Jul 5, 2011 08:51 PM
Hussler
Feb 12, 2008 08:29 PM
