Redline
Old Jan 15, 2001 | 02:37 PM
fastmov4's Avatar
fastmov4
Redline
This is a really simple question, but: what does the 300 redline at? I know peak power comes low...Thanx in advance.
Chris Mitchell
Auburn, AL
'85 F150 4.9L
- K&N Filtercharger
- ICE by Pioneer/Eclipse
Old Jan 15, 2001 | 05:22 PM
StrangeRanger's Avatar
StrangeRanger
Redline
Peak HP is at 3400 RPM. Redline?? My tach doesn't have one and I've never revved it high enough to get into the rev limiter. I'd guess somewhere around 5200-5500, but since you're losing power above 3400, why bother?
Old Jan 18, 2001 | 06:46 PM
Motorcraftsman's Avatar
Motorcraftsman
Redline
id agree with 3500, though ive had mine to 6000(never will do it again)
John Floyd
South Mills,NC
'86 F150 2wd 300 6
Crane Cam 260/272
stock manifolds, w/ staight pipe
Old Jan 19, 2001 | 03:58 PM
oldblue18's Avatar
oldblue18
Redline
Ok, the peak hp is at 3400. Since my father swears up and down that you will "float" the valves if you rev it up that far sitting still, how fast will i have to be going to reach 3400 rpm with a C6? I'm guessing about 120-ish..
Old Jan 19, 2001 | 05:00 PM
oldblue18's Avatar
oldblue18
Redline
sorry....pay no attention to the above post. It never crossed my mind to gear it down.
Old Jan 22, 2001 | 04:54 PM
77fromheaven's Avatar
77fromheaven
Redline
does that torque peak hold true for a 300 from 1977????
Old Jan 23, 2001 | 01:35 AM
kaisermat's Avatar
kaisermat
Redline
You all say that 3600 is the max power range? I can't even bring mine up to 3000 without it sounding like it is ready blow up, is this normal? I have a '81 300 with all stock features.
Thanks,
Matt
Old Jan 23, 2001 | 11:52 AM
Motorcraftsman
Redline
any above idle speed you run an engine without a load on it should be considered the redline.
John Floyd
South Mills,NC
'86 F150 2wd 300 6
Crane Cam 260/272
Old Jan 23, 2001 | 05:47 PM
brown 4x4's Avatar
brown 4x4
Redline
I've always heard 4000 is about tops for the 300. I've never had mine past 3500, and from the sound at 3500, don't know if I want to.
1986 F-150 4x4 300 I6 NP435
Old Jan 29, 2001 | 08:41 AM
fastmov4's Avatar
fastmov4
Redline
I know this is late in the game to mention this, but I could swear that I read different RPMs on max hp and torque. I saw (in a service manual at Books-a-Million, I think) that peak hp of 140 came at 2800 RPM, and peak torque of 280 lb.-ft came at 2000 RPM. If somebody knows differently, let me know!
Chris Mitchell
Auburn, AL
'85 F150 4.9L
- K&N Filtercharger
Old Jan 29, 2001 | 08:15 PM
secondstar's Avatar
secondstar
Redline
Not too sure on redline, but I would have to agree with most everyone in this thread that having a 300 above 3500 is a scary thought. Mine just won't go any higher than about 3200 and doesn't appear to have any power left when it gets that high.
Old Jan 29, 2001 | 08:35 PM
77fromheaven
Redline
i can agree my 77 i-6 has no power after 3000 or so.
it seems to accelerate best around 1700-2500, i guess.
i dearly wish i had more than a three speed tho....
Old Jan 30, 2001 | 09:39 AM
TallPaul's Avatar
TallPaul
Redline
I have had three 300 I6's and never took one over 4000; however, they seem to put out good power at least into the high 3000s. I now generally will shift at about 3500 to 3600 if I am standing on it. I bought a tach that only goes to 4000 so I dont need a redline. Mine is a '95 and the spec is hp peak at 3600 rpm so it has got to be good for at least that and a few hundred more, but who needs it, this motor pulls great in the 2000 range.
Old Jan 30, 2001 | 12:15 PM
cgl's Avatar
cgl
Redline
In my 90 300-6, I would hardly take it above 3100. The noise scared me the most. But after I put in the MSD 6AL and MSD TFI Coil, that engine will pull 3500 with power to spare.
Old Jan 30, 2001 | 05:35 PM
matt68's Avatar
matt68
Redline
true4.2
2004 - 2008 F150
Sep 17, 2010 05:49 PM
Tyler Burdett
53
May 11, 2009 12:59 AM
7FORD2
26
Apr 5, 2006 09:29 PM
eco
Jan 28, 2006 10:03 AM
qwpo
3.8 & 4.2L V6
15
Aug 27, 2004 12:36 PM
