redline for a 390
Old Mar 19, 2006 | 08:38 PM
7FORD2's Avatar
7FORD2
Question redline for a 390
what is the redline for a 390 engine?
Old Mar 19, 2006 | 09:05 PM
rusty70f100's Avatar
rusty70f100
If it's stock, depending on year, I wouldn't go above 5500. The later truck motors, make that 5000, as you wont gain anything above that.
Old Mar 19, 2006 | 10:09 PM
7FORD2's Avatar
7FORD2
ya i dont runit above 4 grand. i cxant afford to tear it up.
Old Mar 19, 2006 | 10:13 PM
rusty70f100
Very wise decision. I found my old 360 ran out of go-power at about 4500rpm. Anything above that was just noise.
Remember, RPM = Ruins People's Motors.
Old Mar 19, 2006 | 10:35 PM
76 F-150 390FE's Avatar
76 F-150 390FE
i have a 390 C6 3.50s and 32" tires when i had my foot to the floor the tranny shifted to 2nd at 55. it was probably more like 60 and probably around 5500-5600. if it hadent shifted right where it did i was going to let off becuase it was screamin and i was going WAY too fast for the 20mph mountain road i was on. but i found a straight away and couldent resist.
Old Mar 28, 2006 | 09:28 PM
Tyqmonn's Avatar
Tyqmonn
5600???? I didn't think a 390 would be safe over 2500. ROFLMAO Really though... It depends on your build. My 396 (.030 over 390) will easily turn 7500 and that's with a Hydraulic cam. Most people think they will EXPLODE at over 4500. A bone stock 390 will usually float the lifters(Hyd.) at around 5000 - 5500. Add a few goodies and they will "scream" way past 5600. JMHO. - Tyqmonn.
Old Mar 28, 2006 | 10:35 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
You must of used that new math again, rpm's at 60 mph on a C-6 in second with a 1.46:1 2nd gear ratio with 3.50 gears, this is without allowing for converter slip so add 250 or 300+ rpm's, may be more with a loose converter call it 3,520 rpm's at 60 mph. This will get you 58.66 rpm's per/mph, so 5,000 rpm's will get you 85 mph. Tire growth will lower your rpm's as speed increases, a small percentage.
I have pulled 2nd with a 414 to 5,400 rpm's, this is 92 mph.
.....=o&o>.....
Old Mar 29, 2006 | 12:52 AM
Bear 45/70's Avatar
Bear 45/70
Most car motors are good to 4500 to 5500 depending on whether it is 2 or a 4 barrel.
Truck motors, because of the cam generally die by 4000 to 4500.
All these engines will rev higher but are not accerating as fast as they were below the max power point. Mainly you are beating the motor to death for nothing.
Old Mar 29, 2006 | 10:02 PM
76f150_4x4_360fe's Avatar
76f150_4x4_360fe
granted my 360 is bored and all kinds of goodies but when I was racing I ran it up to 5500 and tore up absolutley nothing but I still try my hardest to keep it under 4000, usually never get over 3500
Old Mar 29, 2006 | 10:39 PM
"Beemer Nut"
With banging 5,500 on occasion you have more guts than me, I did that with a 473K mile 360 with cam, headers, intake 4 barrel but didn't care as the 414 was ready to install. I wanted to blow it up. You might be beyond the tq and hp useful operating range of that motor besides shortening it's life ten fold.
.....=o&o>.....
Old Mar 29, 2006 | 11:48 PM
fordeverpower's Avatar
fordeverpower
its best to keep a stock 390 at or under 4500 rpm. At that point your are making more noise than anything. my current 390 has a 5800rpm limit wether its the lifters or springs, i do not know.
Had the truck out today for a top speed run, got 4400 out of 3rd gear with 29.5 and 3.50's.
Old Mar 30, 2006 | 12:08 AM
Bear 45/70's Avatar
Bear 45/70
I don't rev my 1984 stock 460 past 4500 either. Why?, because it goes flat at about 4600, so there is no point in it. My other truck with 390 in a 1968 F250 (just don't much use it any more) has a 9 to 1 CR, GT heads, intake, carb and cam plus dual exhaust has no problem with 5500, stock the thing died at just over 4500 also.
Old Mar 30, 2006 | 12:27 AM
"Beemer Nut"
Would that be with manual or auto? At 4,400 without tire growth and manual trans your at 110 mph. No brakes required when you backed out of it, felt like you hit the silk with a Cd. of a low .60 to a high of 1.0 for a truck. As one member stated with OD (which was 3,700 at 100) he should pull redline with a 390, must of been in a vacuum? Sounds like another Bonnieville dream that failed.
You didn't find top end, you were just removing carbon.
.....=o&o>.....
Old Mar 30, 2006 | 01:16 AM
fordeverpower
carl, is that supposed to be some smart *** post or what?
Old Mar 30, 2006 | 01:18 AM
Bear 45/70's Avatar
Bear 45/70
It doesn't really matter how many revs you can pull in 1st and 2nd, because pushing a full size truck thru the air at 100 plus tanks a bunch of horsepower. 120 with a stock truck motor is pretty much impossible and even with a modded motor, it better be better than 450. My stock 1969 Torino Cobra with 428CJ would pull and honest 6000 rpm in high gear with 3 to 1 rear gears, but it was with short tires. But then this body style was pretty slippery, which a truck isn't.
