Are you talking per gear or at the end of your power band??? A buddy has a 4.6...it also has a lot to do with what gears...(3.55/4.10/3.73) you have...
not out of line at all man -- I just bought an EDGE Tuner and was programming shift points because I wanted to test a 1/4 mile run with it. Also, it has a digital tach, so now I can see me RPM's.
@ BNInc
I have 3.55's, but I guess already got my answer from Shotgun. I am looking to upgrade to 4.10 gears with a Ford no-slip diff...see I used to have a 4.2 (hence the name) and I put those gears in it and it made an incredible difference in acceleration.
