Oil Pan Gasket
Old Feb 7, 2001 | 09:29 PM
Raul's Avatar
Raul
Oil Pan Gasket
I have transmission out as well as the flywheel. Think I may need a new one, cracks are easy to see and feel. I'll check tomorrow with a shop to see what they advise.
Very little oil seepage from rear seal, replacement looks easy so I guess I'll do that while I'm here. Any advice, precautions?
Also a little seepage from oil pan gasket - not bad at all. Can I replace gasket without major hassle now that flywheel is out? I am hesitant to lift engine since the exhaust bolts look like they would not cooperate? Can I do it without lifting engine?
If not, I may just leave it till my exhaust needs work. This started out as a transmission rebuild, figuring that if I can't do it, I can just buy a used one. But the deeper I get the more work I find. I don't like the looks of my clutch linkage, I don't like the looks of my clutch, I don't like my throwout bearing, I don't like my flywheel - clutch and pressure plate look good. Blah, Blah, Blah. Sorry.
Appreciate your comments on the gasket replacement -- and anything else, if you have not tires of this message.
Thanks in advance.
Raul
w/ 81 F-100, I6, SROD, Carter 1V non-feedback carb, no A/C, no PS, no PB, but it gets me where I need to go
Old Feb 19, 2001 | 07:27 PM
wenger's Avatar
wenger
Oil Pan Gasket
I replaced my gasket by simply pulling the motor mount pins and hooking my engine puller up to the engine. I raised as high as the fan shroud would let me, about 3 inches. seemed to be enough. I never took the exhaust loose.
I am currently trying to find out why my op gasket is pushing out under the oil filter?
later Chris
Old Feb 24, 2001 | 08:43 PM
Trail_Rider's Avatar
Trail_Rider
Oil Pan Gasket
HUH?!?!?!?
Trail Rider
>oil filter?
>later Chris
Old Feb 26, 2001 | 03:39 AM
bigsix's Avatar
bigsix
Oil Pan Gasket
[font size="1" color="#FF0000"]LAST EDITED ON 26-Feb-01 AT 04:41 AM (EST)[/font][p]Raul:
In re: (only) to your flywheel's condition, don't count it out yet. The flywheel that came out of my '81 (driven extensively before I got it w/ a slipping clutch) was "burned blue" and cross-checked, from high heat, but the machine shop cut @ .028 off it and it looked perfect and has remained factory smooth in its operation. The cracks were "easy to see and feel" on this mine as well, but shop said it would be ok and it was.
Old Feb 26, 2001 | 02:46 PM
paulg's Avatar
paulg
Oil Pan Gasket
vroom9
Jan 17, 2017 07:11 PM
jimbbski
Aug 7, 2015 01:41 PM
F250_
Jan 12, 2015 11:15 AM
jadmt
Oct 18, 2008 08:27 PM
saint_berzerker
Oct 29, 2007 08:36 PM
