95 f150 swapping from auto to manual?
hey guys i have a 95 f150 with a 302 and the 4r70w transmission. well its got 122k on it and im starting to get the common tcc shudder from my transmission. i just scraped my old 88 f150 but before i did i grabbed the zf 5 speed, transfer case, driveshafts, petals, etc. when i had my old 88 on the road that manual transmission never gave me a single problem. but could i swap that older 5 speed into my never 95 with no problems? i know this 4r70w is a computer controled transmission so will i have any computer or driveability problems from the truck? im not new to the whole auto-stick swap as i just did my 85 z28 2 years ago and im still running an automatic computer in that with no driveability probs.
on
I did such a swap on my '91 F150 and the hump is different. You just need the removeable hump from the manual trans truck and then you cut a hole in your floorboard (already indented for you) and mount the cover you got from the donor truck. It'll make the carpet fit tight because the manual hump is taller. I slit my carpet at the very bottom of the hump (underneath the floor mats) to make it fit better.
I just finished doing this swap in my F150 4x4. I went from an E40D to the M50D out of an 89 F150 4x4. I had to fabricate a new trany mount because the M50D tranny is 2" shorter than the E40D and the Frame in my truck changed thickness just infront of my original tranny crosmember, so I couldnt just move it forward. the welder and som stock from Home Depot took care of that problem. The tranny hmp was just fine I cut a hole in it for the shifter to come through and made a floorboard boot out of a piece of 22 guage sheet metal and som 1/8" rubber sheet and used some rtv to make sure it seald good.
Remember the starter is different from the auto to manual, the manual starter has a shorter nose on it because the ring gear on the manual fly wheel is closer tot the block than the auto flex plate. The other thing I ran into is the motor plate (dust cover) has a different size hole in it for the starter. The manual sterter for mine is .067" larger diamiter than the auto starter.
just some things to check while its apart so your not under there with every thing assembles trying to grind out the motor plate...
The following users liked this post:
what do i need to do to wire in my reverse lights on this swap. so far everythings going smooth. ive got the auto trany and transfer case out, i have swapped in the new petal assembly and im now bolting the new steering colomn in. i just need to know what do do to make the reverse lights work?
I gonna chime in a little late, but i hope this helps. First, this is a complete bolt in swap, there should be no cutting/welding/ or drilling (except carpet). As hard as that is to believe, its true, ive done the swap before on my old 92 flareside.
A manual tranny hump pan will bolt right in. As will the crossmember out of an manual truck. The only thing that will need to be modified will be your driveshafts, assuming that your donor truck has a different cab/bed configuration.
Otherwise, everything bolts in.
You will throw tranny codes, but, they wont trip the check engine light.
You will need to wire your neutral safety switch.
These pics are from my swap they may be some help
http://fordtruckworld.tenmagazines.c...sp?album=53910
