Sponsored by: Real Truck
Change the steering wheel?
Old Jan 6, 2008 | 07:24 PM
JEB70's Avatar
JEB70
Originally Posted by phill1060
is there any way to add audio functions to a new 08 steering wheel? I see there is a cut out for it.
I couldn't help you here - I've never even been inside the new '08's. Do you have an '08 and are wanting to add audio controls?
Old Jan 10, 2008 | 09:08 PM
phill1060's Avatar
phill1060
I would like add audio controls to my truck. There is a cut out square in the steering wheel as if a module could fit into that spot.
Old Jan 11, 2008 | 10:43 AM
JEB70's Avatar
JEB70
I'd like to know if i could add audio controls to an '05 steering wheel with the factory stereo. My Jeep has them on the steering wheel and they are great. When I'm in my F250 and I want to change the station I instinctively go to hit the radio controls on the steering wheel like the Jeep. It's kinda a long reach over to do it the old fashioned way :biggrin:
Old May 23, 2008 | 03:11 PM
Citypol86's Avatar
Citypol86
Originally Posted by RACERX7775
thr radio controls work because i got a harness and the adapter to use factory contrls with an aftermarket radio. the climate control buttons dont because my X is an 01 and it has the manual a/c controls. i mainly did it for looks because my factory wheel was looking crapy.
Racer, I just picked up the same wheel. It's from an '05 SD King Ranch. I took everything apart and just before I pulled the old wheel, I saw that the old plug is very different from the new one. The stock plug is a five-prong and the King Ranch is a seven-prong. What harness and adapter did you use to get the two to mate?
For now, I'm just going to reassemble until I can sort out what I need to do.
Also, I'm assuming that the cruise control also works. It that correct?
Thanks,
Later...
Brewster...
Old May 23, 2008 | 05:13 PM
cartmanea's Avatar
cartmanea
I replaced the driver's airbag after rebuilding mine, wasn't a big deal. A friend who works at a dealership told me they tried to make some old airbags go off before and it is very difficult. All the warnings are mostly for liability purposes. There is a tab on the plug that shorts the pins when disconnected to protect against static electricity.
That being said, I wore safety glasses and didn't put any tools or sharp objects between me an the bag when installing it. I also wore safety glasses the first time I started it after that. Also, I kept the windows down the entire time to reduce the concussion in the cab in case it went off. Better safe than sorry.
Old May 23, 2008 | 07:48 PM
RACERX7775's Avatar
RACERX7775
the cruise control had to be rewired. the harness is from an 01 navigator not an 05 super duty. the conector is one of those made from PIE. i am not sure on the wiring from the new truck..sorry, i know that i didnt help...
Old May 24, 2008 | 06:40 PM
Citypol86's Avatar
Citypol86
Thanks, Racer, its a starting point...
Later...
Brewster...
Old May 28, 2008 | 08:52 AM
Mike E's Avatar
Mike E
Change '05 SD wheel to '08
Anyone know if the new style steering wheels are compatible with an '05.
The new ones are so much better.
creedua
19
Jun 11, 2014 01:01 PM
benbuilder
Oct 26, 2013 04:31 PM
TireJockey
Aug 8, 2013 05:37 PM
shortblock2000
Mar 19, 2006 08:55 PM
RippedBronco
1978 - 1996 Big Bronco
May 6, 2003 11:45 PM
