Steering Wheel Not Lining Up Straight
Old Mar 17, 2006 | 09:02 PM
shortblock2000's Avatar
shortblock2000
I have a 1986 ford f150 and when I get the front wheels straight the steering wheel is not straight. What do I need to do to adjust the steering wheel or front linkage to get everything straight?
Old Mar 17, 2006 | 11:38 PM
Nathane's Avatar
Nathane
get an alignment, or pop the stearing wheel off, and move it to suit you
most times you get an alighment is after new tires
~Nate
Old Mar 18, 2006 | 01:27 PM
Neb86's Avatar
Neb86
To straighten the steering wheel you need to adjust the tie-rod ends.
Set your wheel straight ahead. Look at your wheels, if they are turned slightly left then you will have to shorten the drivers side tie rod and lengthen the passenger's side the same amount. The opposite applies if the wheels are turned to the right.
It's a pretty straightforward job but, you might have to do it a time or two before you get it right.
I don't recommend that you remove your steering wheel and replace it straight. That might work but, your turn signal cancelling will be messed up (not that anyone uses turn signals anymore).
Good luck!
Old Mar 19, 2006 | 12:00 AM
Nathane's Avatar
Nathane
how would the signal canceling cam get screwed up from removing the wheel? I thought it was under the collet for the nut, but I havent ever had a ford colum apart though... 87 mazduhh b2200 truck, and 76 MB 300D... both were seperated from the cam
Can you explain more?
tks alot
~Nate
Old Mar 19, 2006 | 03:58 AM
Neb86's Avatar
Neb86
tks alot
~Nate
That is true, the wheel doesn't physically cancel the signal but, if the wheel isn't straight, the column is turned as well and the do-hicky (technical term) that hits the cam is closer to one spot than it should be when you are in the straight ahead position. So it will cancel sooner when you turn right (for example) than when you turn left. And the left may not cancel at all in some situations.
If the wheel was responsible for canceling the signals, then removing it and putting it back on straight would work just fine.
Old Mar 19, 2006 | 09:39 AM
beaners1's Avatar
beaners1
I would get an alignment done if you haven't done it recently, things have a tendancy to wear out and move. I've always considered an alignment good maintance for my tires. The alignment only costs me around $100, my tires cost $250 each. IF your shop tells you that nothing is wrong with the alignment then you know that's not the problem and you have the peace of mind knowing that the steering system under the truck is in good order.
Old Mar 19, 2006 | 08:55 PM
Chiefrider007's Avatar
Chiefrider007
If nobody has taken the steering wheel off the truck and gotten it back on in the wrong spot, then the only thing left is alignment.
MKLC
Jan 10, 2016 11:50 PM
SoCalAngler
22
Feb 28, 2015 09:03 AM
jonrjen
6.7L Power Stroke Diesel
Feb 20, 2015 07:26 PM
ddzmann68
Feb 19, 2015 08:45 AM
Dan Taylor
Dec 2, 2013 07:48 AM
