I'm thinking about getting another SD and I HATE the standard steering wheel. After having the sport wheel in my 350, I will need it from now on.
SO, what does it take to swap the steering wheel as far as the airbag goes? Is it just unplug it, unbolt the wheel, or is it a bigger deal(ie need a body shop to do it)?
We shade tree mechanics are discouraged from working on and around air bags.
If you do attempt to swap the wheels, disconnect the battery and please use a wrist grounding strap. Stray static electricity discharge will cause an inadvertant air bag deployment.
I've worked with a lot of explosives and I know how easy it can be to set off the squibs that cause the air bag deployment. Be safe, you don't want this thing going off in your face.
You can swap steering wheels yourself. Borrow a steering wheel puller from AutoZone to pull the old wheel. Then disco the battery. The airbag is held in by 2 bolts behind the wheel. Remove them. Next, disconnect the one wire connector for the airbag and remove the airbag. Don't be afraid - you don't need a hermetically sealed white room to take it out yourself - it's not going to go off in your face. Now use the steering wheel puller and pull the wheel. Now disconnect the wires for the cruise and if you have them the radio controls. Installing the new steering wheel is the opposite of removal.
I've replaced the worn leather steering wheel on a Grand Cherokee and also swapped the standard steering wheel with a leather wheel bought from EBay for my '05 F250.
thr radio controls work because i got a harness and the adapter to use factory contrls with an aftermarket radio. the climate control buttons dont because my X is an 01 and it has the manual a/c controls. i mainly did it for looks because my factory wheel was looking crapy.
If you know, is there a harness that will control the factory in-dash 6-CD AM/FM Stereo? Also, is the wiring compatible with my present cruise control? [All I have is cruise control on the wheel now.] This is on an '05 SD F250 Crew Cab.
Also, was that price including the air bag?
Later...
Brewster...
Reason: Additional question
Later...
Brewster...
You remove the switches from your old wheel and put them into the new wheel - very simple to do.
But like I said, I only have cruise right now. Is there a harness needed to connect the wheel to the column or is the wiring in the column already and just needs the wheel to be plugged into it?
Yes there is a plug in the column already there.........
