Sponsored by: Auxito
Transfer Case Fluid ???
Old Dec 15, 2007 | 03:23 PM
DJPRacer58's Avatar
DJPRacer58
Dose the transfer case have its own fluid or dose it run off the trans?
99 F-150 5.4L Lariat AT Auto Shift transfer case.
thanks derek
Old Dec 15, 2007 | 04:02 PM
BLK94F150's Avatar
BLK94F150
It has its own fluid and I'm 99% sure that it uses Mercon.
Mike
Old Dec 15, 2007 | 06:58 PM
steve(ill)'s Avatar
steve(ill)
it holds 2 quarts. drain below the drive shaft, fill about the shaft level. look like 1/2 inch pipe plugs with 3/8 square drive holes. fill with the same stuff in your transmission, MERCON or V.
Old Dec 15, 2007 | 07:07 PM
xtrford's Avatar
xtrford
I was educated earlier on that it has to be changed at regular intervals.....be ready for a mess because the damn fluid pours out on the cross member and splats everywhere.
bullnose1985
30
Dec 15, 2014 11:58 AM
Andy Sullivan
Feb 15, 2014 04:52 PM
slowmans
Jan 19, 2008 07:22 PM
B1GKAHUNA
Mar 25, 2007 10:27 AM
Bill4Ford
Nov 3, 2002 04:15 AM
