Sponsored by: Auxito
vacuum leak
Old Dec 14, 2007 | 07:42 AM
59shortbed's Avatar
59shortbed
vacuum leak
I know that I have a Vacuum leak because my heater blows from the floor to defrost when I step on the throttle. My question is "what is the best and quickest way to locate it".It is a 97 f150. Can I spray carb cleaner around the hoses or is this a BAD idea ?
Old Dec 14, 2007 | 07:55 AM
ranger88a's Avatar
ranger88a
Look around by the battery for a broken line or one thats disconnected, thats usually where I find the leak you describe.
Old Dec 15, 2007 | 07:19 AM
LxMan1's Avatar
LxMan1
Yep, it should go into the fenderwell where the vacuum canister is.
Old Dec 15, 2007 | 01:35 PM
59shortbed's Avatar
59shortbed
thanks, I'll check it out today before it snows
Old Dec 15, 2007 | 07:04 PM
steve(ill)'s Avatar
steve(ill)
the vacuum line comes off the motor and heads dwon the firewall toward the passenger side and goes behind the battery to an accumulator. in front of the glove box, on the firewall there is a TEE in the plastic line. the line TEEs and goes into the firewall toward the heater control. Look at the TEE, and the hose ends, and the line toward the battery.
Old Dec 15, 2007 | 07:50 PM
59shortbed's Avatar
59shortbed
thanks for the help. I checked out the vacuum lines today and found that the vacuum line from the tee to the res. had a crack in it. i taped it up so that i can see if this will fix my problem. We will be having a nor-easter coming in tonight so i will not be able to make sure that this was the only leak. thanks for all the help in locating the place to start trouble shooting.
daculpepp
Dec 28, 2013 09:57 PM
NorminN.B.
2009 - 2014 F150
May 11, 2013 09:39 AM
Redcat Diesel
Jan 25, 2009 01:31 PM
tractoman
May 30, 2007 09:55 PM
xKirkx
1978 - 1996 Big Bronco
Mar 20, 2004 01:24 AM
