Random E4OD limp mode
Old Dec 14, 2007 | 09:25 PM
George D.'s Avatar
George D.
Today on the way to work my trans started shifting hard about 1/4 mile from home. I was still kinda tired and didn't think much of it untill I realised the OD cancel light was flashing Then I relised I was in limp mode so I pulled over to call in to work because a trans rebuild cost way more than I make in a day and I had about 15 miles to go. But I decised to start the truck back up and see what hapened And every thing was fine. I'm gona check to see if the wires from the vss or tach are shorting to anything in the morning But was woundering if there were anything els I should check? Thanks.
Old Dec 14, 2007 | 09:46 PM
PLC7.3's Avatar
PLC7.3
The FIPL/TPS may be part of the problem too..it tells trans when to shift relevant to excellerator position.........
Old Dec 14, 2007 | 09:48 PM
David85's Avatar
David85
If your OD light is flashing, and hard shifting your computer has probably stored a slip related falt code, so you should get that scanned first.
Old Dec 14, 2007 | 10:09 PM
George D.'s Avatar
George D.
Thanks guys I'll check that stuff tomarow by the way what dose FIPL stand for any way just curious.
Old Dec 14, 2007 | 10:14 PM
PLC7.3's Avatar
PLC7.3
Fuel injection pump lever sensor......... the thing on the drivers side of the IP with an electrical connection....... Click on my name and email me I will forward more info/pics.
Old Dec 16, 2007 | 12:29 PM
ford trans tech's Avatar
ford trans tech
a scan first please , throwing parts at it like a fipl , tach sensor or speed sensor is a waste of good money without knowing what system is at fault
umpalumpa1985
17
Oct 17, 2022 01:12 PM
finitetime
20
Oct 8, 2022 11:59 PM
RIKIL
39
Mar 6, 2020 03:18 AM
351w5.8
New Member Introductions
Jul 14, 2016 07:47 PM
plowboycowboy
Jul 20, 2015 07:44 PM
