E4OD Limp Mode
Old Oct 18, 2015 | 02:19 PM
RIKIL's Avatar
RIKIL
E4OD Limp Mode
What happens to the trans when it goes into limp mode? What does it do differently?
Does the ECU do anything different when the trans is in limp mode?
Old Oct 18, 2015 | 02:27 PM
jaagen's Avatar
jaagen
From what I remember read on this forum it increases fluid pressure as to not burn it up. I could be wrong imsure others will know exactly.
Old Oct 18, 2015 | 03:19 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The entire limp mode is IN the ECU. It commands a higher pressure, and depending on what the problem is, it can limit what gears to use, and even how much torque the engine can produce.
Old Oct 18, 2015 | 03:34 PM
RIKIL's Avatar
RIKIL
I just pulled codes and I get 652: modulated lock-up torque converter clutch solenoid circuit fault.
What would this to do the behavior? My shifts are not nearly as hard as before, which is when I noticed an issue. OD light blinks. Would the ECU reduce power in this situation?
Old Oct 18, 2015 | 05:48 PM
Mark Kovalsky
No, it would not. That will prevent your torque converter from locking, but not much else.
Old Oct 25, 2015 | 06:41 PM
RIKIL's Avatar
RIKIL
OK, definately not in limp mode. However, I did find the fluid was low by about a gallon. Once I got the fluid level correct I took it out for a drive. I am getting hard shifts into reverse and it seems like the shifting from 1-2 and 2-3 is short, meaning not long enough. So something is still not right.
Suggestions on how to troubleshoot?
Old Oct 25, 2015 | 07:26 PM
Mark Kovalsky
Check the fluid level again. Do it with the trans warmed up and the engine idling in park. I don't think the trans would operate if it were really a gallon low, so now I think you have overfilled it.
Old Oct 25, 2015 | 07:47 PM
RIKIL's Avatar
RIKIL
Today when I started the truck I let it warm up to full operating temp before even shifting into drive. When I shifted into drive I noticed some gurgling sounds coming from the trans so I pulled the dipstick and it was dry. I left the motor running and would add fluid, a quart at a time, shift through the gears and then check the fluid level. After 1 gallon I got it to the right spot.
Old Oct 26, 2015 | 11:33 AM
Mark Kovalsky
The trans won't warm up idling. It needs to be driven to get warm enough to check the level.
Old Oct 26, 2015 | 11:34 AM
RIKIL's Avatar
RIKIL
ok, I will make sure to do that when I can, might be a day or two.
On the possibility that might trans fluid was low...if it was so low that the solenoid assembly didn't have enough fluid in it, could it be damaged if I drove it long enough?
Old Oct 26, 2015 | 01:48 PM
Mark Kovalsky
The problem isn't the solenoids not having enough fluid. It is that the pump sucks air instead of fluid. This can damage the pump because it doesn't like to run dry. Also, any clutches that are engaged will slip if the pump doesn't maintain pressure.
Old Nov 14, 2015 | 09:48 PM
RIKIL's Avatar
RIKIL
I have heard some people using mercon V in the E4OD. I have always used Mercon III. Any thoughts as to which one I should use? Does it matter how the tranny is built to determine what fluid to use?
Old Nov 15, 2015 | 07:28 AM
Mark Kovalsky
First off you have never used MERCON III. There is and has never been a MERCON III fluid. Ever. There was MERCON, then MERCON V, then MERCON SP, MERCON LV, etc. There never was a MERCON III.
MERCON has been discontinued. Nobody can make a MERCON fluid any longer. There are still fluids available that say, "For use in transmissions that previously used MERCON." What's in those fluids? Nobody knows. When Ford licensed MERCON fluids they tested samples and approved that the fluid met their specs. Nobody does that for these fluids.
Ford still licenses and tests MERCON V fluids. That's the right one to use.
Old Nov 15, 2015 | 07:55 AM
subford's Avatar
subford
Note 652 is a KOEO electrical test only code and would have nothing to do with the fluid level in the transmission.
DTC 652 indicate solenoid did not change state when requested by the Powertrain Control Module (PCM).
Possible causes:
-- Damaged solenoid/assembly.
-- Open or shorted harness (internal/external).
-- Damaged PCM.
Old Nov 15, 2015 | 07:59 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
don't shoot him Mark lol.he just meant dexron 3/mercon.
very common issue of the solenoid pack/bulkhead connector failing.be sure to inspect it.
