Limp mode 4eod
Old Jul 14, 2016 | 09:29 AM
351w5.8's Avatar
351w5.8
Limp mode 4eod
Ok i put a new to me transmission in my 1996 f250 5.8 351w with e40d trans. First voyage out went great 10 miles stayed under 40 no problems. Second trip was longer went about 40 miles at highway speeds. 20 miles in i came to a stop and went into limp mode. Hard shifting 1-2 and 2-3 od light blinking pulled codes found a bad speed sensor. Old tranny was having this same issue plus no reverse and finally pump seal went causing me to swap it. So i have changed rhe speed sensor but cant get it out of limp mode. Tried clearing codes with my scanner and disconnected the battery positive cable for half hour.???
Old Jul 14, 2016 | 07:47 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The most likely cause is a problem with the wiring between the PCM and the speed sensor.
FN250super cab
New Member Introductions
May 10, 2025 04:37 PM
MaxxSpazz2!
Aug 21, 2017 03:05 PM
aroller1
Jun 2, 2009 01:19 AM
