oil consumption
Old May 29, 2001 | 09:20 AM
brown 4x4's Avatar
brown 4x4
oil consumption
Added my first extra quart of oil today with 16K miles (2000 miles since last oil change) on the engine. I know I probably shouldn’t worry about it, but when you hear some people say they never burn a drop with 150K on the engine, it makes you wonder. How much oil are you guys burning and what is considered normal oil usage?
1986 F-150 4x4 300 I6 NP435
Old May 29, 2001 | 03:20 PM
traildawg's Avatar
traildawg
oil consumption
I've got about 30K on my engine now (factory replacement) and usually have to add a quart at about 2000 miles after an oil change.
TrailDawg
https://www.ford-trucks.com/dcforum/User_files/3aaa4bac6f539876.jpg
1993 F150 2WD
6" Pro-Comp Stage II Lift w/35's
Auburn Pro-Series Diff. w/4.30 gears
http://www.geocities.com/ProjectTrailDawg
Old May 29, 2001 | 05:29 PM
Eddie's Avatar
Eddie
oil consumption
About the same as 'Dawg's--my '91 has used a quart in 2000 miles since new, and that hasn't changed in 200,000 miles.
Now that I just got through sticking in a new rear main seal, it just might change--for the better!
Eddie
Old May 29, 2001 | 05:42 PM
87f250's Avatar
87f250
oil consumption
same here with 125,000 on her. on the other hand if i would chang that darn leaking valve cover gasket.......
87 f-250
" if you are going to have a bear, it might as well be a grizzly"
4.9 granny tranny 4.11 gears
Old May 29, 2001 | 05:44 PM
94van's Avatar
94van
oil consumption
I haven't needed to add oil between 3,000 mile changes, 69,500 miles at present.
94 E-150 High Top Conversion Van 4.9/C-6
89 Mustang LX 5.0 - 5 speed
Old May 29, 2001 | 05:56 PM
mudinford's Avatar
mudinford
oil consumption
Old May 29, 2001 | 09:29 PM
MSTRAWN's Avatar
MSTRAWN
oil consumption
Before I added the pcv sludge box my engine did not need to be topped off in between the oil changes. I noticed that it has used half a quart now at 2000 miles. When I drained the sludge box I found the missing oil. Guess I had better install some kind of orifice in the vacuum hose to cut down on the suction a little. The engine has 32,000 on it since the last rebuild.
1977 F-100
300 I-6 / C-4 (soon to be AOD)
Offy C intake w/Edelbrock 500CFM
Hooker Ceramic coated headers w/duals, turbos, tips, and 02's
MSD6A w/Blaster Coil
Headlight relay system (Delanty style)
Overhead Mount FM-CD etc.
R-134 A/C system (I'm cool)
Old May 30, 2001 | 01:18 AM
hood's Avatar
hood
oil consumption
Unless my dipstick grows when i pull it out, i am always in the "safe" zone when i check my oil level. Every 3,000 miles the oil is changed and she is never low. Im at 197,500 miles and counting down. Just did the oil change today, so the next one will be at the 200,000 mile celebration.
All my other vehicles use a half quart to a full quart around the 2000 mile mark. Your useage sounds very normal.
1981 F-150 2WD STYLESIDE P/U
4.9L 1 BBL CARB
C6 AUTO
2.73:1 LIMITED SLIP REAR AXLE
STABILIZER BARS FRONT & REAR
6100 LB GVWR PACKAGE
ORIGINAL OWNER
197,500 PLUS MILES
100% STOCK & UNREBUILT
BUILT FORD TOUGH!!!
Roofer Girl
Nov 18, 2010 07:27 PM
mongoo
2009 - 2014 F150
18
Aug 8, 2010 11:21 AM
mackda600
Feb 15, 2010 06:12 PM
catan70
1997 - 2003 F150
Jan 18, 2010 09:28 PM
Frank Lang
Jul 13, 2004 04:21 PM
