'92 F150 5.8L using/burning huge amounts of oil - Ford Truck Enthusiasts Forums
Old 11-11-2010, 11:16 AM
Roofer Girl
Roofer Girl is offline
Roofer Girl is starting off with a positive reputation.
I have a '92 f150 with a 5.8L using/burning a quart of oil to every 60miles if i drive nicely on hwy. Yesterday we had wet snow and I only drove 100miles but used 3.5quarts of oil. cause I used 4x4. We have tried changing the Pvc valve. Check engine light goes on and off randomly, also after driving at hwy speed then having to stop oil gauge flickers between no pressure and only goes back to pressure when put in park or driving resumes. This truck has 440K. Any ideas on fixes or is motor on it's way out? No knocking noises, if you didn't know I added oil all the time you wouldn't know there was a problem.
Old 11-11-2010, 11:53 AM
lew52's Avatar
lew52
lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
Well 440K isnt alot of miles for a ford , but you might want to do a compessoin check , the rings may be worn , after you check the comp put a little oil in each cylinder & check it again , if it goes up thats a sign of bad rings ....Lew
Old 11-11-2010, 01:43 PM
Duct Tape Racing's Avatar
Duct Tape Racing
Duct Tape Racing is offline
Duct Tape Racing is gaining momentum as a positive member of FTE.
440k? When was it last rebuilt? I can bet your rings are goin bad and it's burning oil like a striped *** ape
Old 11-11-2010, 09:04 PM
CWPottenger
CWPottenger is offline
CWPottenger is gaining momentum as a positive member of FTE.
Is it smoking out tailpipes? If your not smoking badly it must be leaking.... if you look under truck is it coated in oil? If valve covers, oil pan, or rear seal shot you will loose a ton! of oil....
Old 11-18-2010, 02:12 PM
Roofer Girl
This engine has not been rebuilt that I know of. Have had a compression check done. At least I think that's what was done 4-6 lbs pressure in engine. This truck has always had a leak where it meets the tranny, but what is new is it's blowing a tonne of oil threw the air filter, and running down the drivers side wheel well. The truck does smoke on startup and sometimes on excelleration, but not all the time. I have been hoping for a cheap fix for this truck. (been in denial about the engine being done) So anyway I am looking for another motor for this truck. Not having much luck.
Old 11-18-2010, 02:21 PM
thndrroad70's Avatar
thndrroad70
thndrroad70 is offline
thndrroad70 is starting off with a positive reputation.
with 440k on it I would just start looking for another motor......
Old 11-18-2010, 02:32 PM
Roofer Girl
Like I said in my last post, I am looking for a new motor, just not having any luck. If I have to rebuild the one that's in my truck, I may have to go without wheels for awhile. Trying to avoid that.
Old 11-18-2010, 02:35 PM
thndrroad70
where are you located??
Old 11-18-2010, 02:48 PM
Samsonitesamsonite's Avatar
Samsonitesamsonite
Samsonitesamsonite is offline
Samsonitesamsonite is starting off with a positive reputation.
oil in the filter is usually do to blow-by aka bad rings, especially since you already replaced the PCV.
Old 11-18-2010, 03:05 PM
Roofer Girl
My closest city is Regina, SK. Canada.
Old 11-18-2010, 04:15 PM
thndrroad70
Sorry , your to far away for me to help.... kinda surprising that they arent falling off of trees in Canada, where the trucks themselves I would expect to rust away within a few years leaving only driveline parts scattered throughout the countryside... atleast thats what happens here in connecticut and seems to get worse as you go north.... I always have a yard full of great drivelines but nice bodys are almost extinct around here.....
Old 11-18-2010, 04:29 PM
Roofer Girl
That should be the case, but believe it or not. My truck is a relic here, or so it seems. I do have a couple of mechanic friends of mine searching, no luck so far. I had the front axle replaced in July and they had to get it from Alberta. Hopefully they find something soon. I use this truck for work too.
Old 11-18-2010, 07:27 PM
Kapusta's Avatar
Kapusta
Kapusta is offline
Kapusta is a splendid one to beholdKapusta is a splendid one to beholdKapusta is a splendid one to beholdKapusta is a splendid one to beholdKapusta is a splendid one to beholdKapusta is a splendid one to behold
I have a feeling she means 440K in kms, not miles. That would be more like 275K in miles.
Finding another engine with low miles would be the ideal scenario for a time and budget fix.
Brittanysmith
04-06-2017 02:47 PM
Delta Echo
2015+ F150
17
10-09-2016 07:36 AM
Skyeric875
1997 - 2003 F150
08-21-2015 06:14 PM
duct tape F-150
19
05-04-2011 12:37 AM
danintx
03-12-2008 10:39 PM
Quick Reply: '92 F150 5.8L using/burning huge amounts of oil
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
