What's it worth?
Old Dec 10, 2007 | 06:54 PM
kawa's Avatar
kawa
Post What's it worth?
I've been looking for a SD 3 Pinion differential third member but the best so far is $425.00 + $ 25.00 shipping out of Ohio. It's out of an 2003 w/12K on it.
I don't seem to be able to come across these $100.00 deals that you folks in the mid-West and South get.
Are you guys just tripping over them because they are so plentiful?
I want one!!!!Any one got an extra? Talk to me
Rog
Old Dec 10, 2007 | 06:57 PM
tjbeggs's Avatar
tjbeggs
Wouldn't pay 425 for it!! you can get an aftermarket unit for that much!
Old Dec 10, 2007 | 08:15 PM
kawa's Avatar
kawa
TJ:
If ya think $425.00 is high I just got call from a guy in Texas that has three, gear ratios of 373, 410, 430. and he only wanted $750.00 + shipping these were from a 2001 SD 4X4.
Can't I just bolt my ring gear to the unit or do I have to use the ring that comes with it? Also, does it make a difference if it's from a 2X4 or 4X4?
Help me out here if you would.. the higer the number the lower the ratio?
If I can't stay at my 355's I would at least stay close if possible.
Rog
Old Dec 10, 2007 | 08:26 PM
tjbeggs's Avatar
tjbeggs
Your rign gear will bolt up to the 3 pinion no problem. And for $750 you had better get a hub to hub axle with disc brakes!!
Old Dec 10, 2007 | 09:14 PM
arkredneck's Avatar
arkredneck
for $420 summit will ship you a powertrax lockrite locker all you have to do is unbolt the axles and the the one bolt the holds in the spider gears slide the axles out a little and take the spider gears out follow the installtion instuctions that come with it and you got a locker so far i'm happy with mine no clutches to go out
$F$O$R$D$
Vehicles for Sale
May 25, 2016 06:00 PM
Sous
13
Feb 26, 2016 01:02 AM
khadma
15
Feb 19, 2016 02:25 PM
oreocreaming
North Carolina Chapter
Apr 29, 2011 02:24 PM
