Which would you go for?
Old Dec 10, 2007 | 08:02 PM
superduty4x4's Avatar
superduty4x4
Option #1. 95 F350 XLT crew cab, PSD, auto, 185K, 4" or so lift, newer 35's on aluminum wheels, minor damage to tailgate, fender flares, wood grain dash, tow package, grille guard, CD player.
Option #2. 97 F350 XLT crew cab, PSD, auto, 192K, stock wheels w/decent tires (no lift), shell on the bed, Rhino lined (w/carpet kit for shell), tow package, decent shape inside/out.
Could probably get my hands on either one for $8500-$9000. I'm drawn to the 95, wife likes the 97
Old Dec 10, 2007 | 08:09 PM
superduty4x4
Forgot to add, the 95 has a DP, superchip, and I think exhaust, the 97 has gauges (don't know which ones or how many).
Old Dec 10, 2007 | 08:14 PM
strokin'_tatsch's Avatar
strokin'_tatsch
i would go for the '95 and tell the wife that it's cause it's got lower miles, but really you probably want it cause of the lift, tires/wheels, and the exhaust!!!! ... but if your lookin' at putting a SD HPOP on the truck then i would go ahead and get the '97 because it's going to be a lot less work to do than on the '95.
Old Dec 10, 2007 | 08:15 PM
tjbeggs's Avatar
tjbeggs
The 97. Gauges are more expensive than a DP plus it shows that the owner knew to keep things in check. Though it may also mean it had a chip in it.
The 97 will have more updates on the tranny and the superduty hpop will be a direct fit unlike the 95. Also the 97 has 225hp and the 95 has 215
Old Dec 10, 2007 | 08:22 PM
superduty4x4
What's the benefit of an upgrade to a Super Duty HPOP? And does 10 HP really make that much of a difference? I will agree that tranny updates would be a big plus though!
Old Dec 10, 2007 | 08:27 PM
tjbeggs's Avatar
tjbeggs
The benefit of the SD HPOP is higher ICP pressures to drive the injectors once a chip or larger injectors are added. And no the 10hp doesn't make much difference. easily overcome with a chip
Old Dec 10, 2007 | 08:32 PM
superduty4x4
Okay sorry guys, now there are 4 players
#3 is another 95 F350 XLT crew cab, 171K, auto trans, don't know anything else because the dealer closed before I got ahold of them. They are asking $12950 which is way high for a 95 IMO, not sure whether or not I could get them down to the same price range as the other two or not.
#4 is another 97 F350 XLT crew cab, 155K, 5 speed, runs and drives good, 5th wheel and bumper hitch, will need tires soon, basically all stock.
Old Dec 10, 2007 | 08:35 PM
superduty4x4
So, how does the HPOP upgrade work with the SD IDM upgrade, do they accomplish the same thing?
Old Dec 10, 2007 | 08:49 PM
strokin'_tatsch
no they do not. the IDM, i believe, ups the voltage going to the injectors, but the HPOP allows for more oil to fire the injectors. the HPOP will be a lot better than the stock b/c once you add a chip then the stocker will not be able to supply the oil demand, but the SD HPOP should be more than capable to supply enough oil to run the injectors.
Old Dec 10, 2007 | 09:13 PM
superduty4x4
Well, now I'm p!ssed. Had a guy lined up to buy my truck, was supposed to pick it up tomorrow, cash in hand. He just called and bailed on me Puts my search for a PSD on hold... again!
Old Dec 10, 2007 | 09:19 PM
arkredneck's Avatar
arkredneck
i think #1 looks the best test drive them all and see which one drives the best
tjbeggs's Avatar
tjbeggs
DUh! Well hopefully you find somebody else.
Old Dec 10, 2007 | 09:27 PM
2 stroke man's Avatar
2 stroke man
hard to say. i like 1&3. nice! see sig-u'll know why. keep in mind i'm young
Old Dec 10, 2007 | 09:29 PM
2 stroke man
second the crackerjack prize TJ! sounds like we may agree on politics, if not on k&n
Old Dec 10, 2007 | 09:32 PM
tjbeggs's Avatar
tjbeggs
Well I will settle for 1 out of 2 of lifes most important desicions!
