My "OH *****" List
Old Feb 24, 2016 | 06:26 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
My "OH *****" List
Below is a list I posted in another thread after a member asked for it. This is simply a list that I have built during my time of owning my 7.3. No matter how reliable and strong our trucks are, ***** happens and when it does I prefer to be ready instead of sitting on my phone trying to figure out what to do next.
I built this list in Excel, so it does not translate very well to the forum, but you can get the idea. It is common problem areas or part numbers and sources I keep on hand just in case. So, lets say my CPS or lower radiator hose goes out, now what? Well, if I cannot fix the problem on site, I go to my list and immediately have the best source (in my opinion) already lined up and get the part sent to me.
Some of the items below are more of a "wish list" thing, but I feel they should be shared anyway.
Enjoy, and share your list if you have something similar.
FRx $200.00 7.3L Diesel Fuel Rail Crossover? (FRx) 99-03 Powerstroke
Female Pipe Socket $8.00 9/32" Square Female Pipe Plug Socket for Ford 7.3L 99-03
Belt (JK81227) $50.00 Motorcraft Single Alternator Serpentine Belt 99-03 - Riffraff Diesel Performance
Belt Tensioner (F8UZ6B209CA) $80.00 Serpentine Belt Tensioner 99-03 - Riffraff Diesel Performance
Air Suspension $400.00
Amazon.com: Air Lift 88390 LoadLifter 5000 Ultimate Air Spring Kit with Internal Jounce Bumper: Automotive Amazon.com: Air Lift 88390 LoadLifter 5000 Ultimate Air Spring Kit with Internal Jounce Bumper: Automotive
Air Suspension Controller $225.00
Amazon.com: Air Lift 25854 Load Controller Single Heavy Duty Compressor: Automotive Amazon.com: Air Lift 25854 Load Controller Single Heavy Duty Compressor: Automotive
Prodigy P2 $125.00
Amazon.com: Tekonsha Prodigy P2 Brake Control for Ford Vehicles (1994 and up): Automotive Amazon.com: Tekonsha Prodigy P2 Brake Control for Ford Vehicles (1994 and up): Automotive
Shocks (logo right side up) $270.00 Bilstein - KYB - Rancho - Monroe - Edelbrock Automotive Truck Shocks and Struts - Shockwarehouse.com
Injectors $1,200.00 Rosewood Diesel Shop
UVCH $120.00 Under Valve Cover Harness 99-03 - Riffraff Diesel Performance
UVC gasket $120.00 Valve Cover Gasket for Ford 7.3L Powerstroke (99-03)
Glow Plugs $85.00 Motorcraft Glowplugs ZD-11 - Ford 7.3L (94-03)
Siphon Gun $22.00
Amazon.com: Milton S157 Siphon Spray Blow-Gun Kit w/ 8 Ft Tubing: Automotive Amazon.com: Milton S157 Siphon Spray Blow-Gun Kit w/ 8 Ft Tubing: Automotive
Cup Brush $17.00 https://www.peterbiltparts.com/engin...ssories/9u6862
Cup Brush Ukn https://parts.cat.com/en/catcorp/4C-6161
Oil Rail Plug O rings $3.50 Oil Rail Plug O-ring Kit for Ford 7.3L (94-03) - GZ-8-003
HPOP $450.00 MB DIESEL 7.3L HIGH PRESSURE OIL PUMP - 99-03-ENGINE - POWERSTROKE 99-03 - Products
HPOP Lines $120.00 CNC FABRICATION 7.3L SD REPLACEMENT HPOP LINES - 99-03-ENGINE - POWERSTROKE 99-03 - Products
Bypass Oil Kit $200.00 Ford 6.0, 6.4 and 7.3 Oil Bypass Systems and Billet Aluminum Filter Caps
Starter $120.00
Amazon.com: DB Electrical SND0355 Starter (d 7.3 Diesel Powerstroke Truck 1994-2003): Automotive Amazon.com: DB Electrical SND0355 Starter (d 7.3 Diesel Powerstroke Truck 1994-2003): Automotive
ICP $150.00 Injection Control Pressure ICP Sensor 97-03
CPS $25.00 Motorcraft Cam Position Sensor CPS 94-03
IPR $185.00 IPR Injection Pressure Regulator 96-03 7.3L Ford Powerstroke
GPR $60.00 Monster White-Rodgers Glow Plug Relay
IH 192 degree thermostat $32.00
Amazon.com: PAI THERMOSTAT (192 deg) 481828: Automotive Amazon.com: PAI THERMOSTAT (192 deg) 481828: Automotive
Lower Radiator Hose $50.00 Gates Vulco-Flex Green Stripe 26517 - Coolant Hose | O'Reilly Auto Parts
Battery Terminals $31.00
Amazon.com: Military Spec Battery Terminal Top Post Kit: Automotive Amazon.com: Military Spec Battery Terminal Top Post Kit: Automotive
Bosch Fuel Pump $90.00
Amazon.com: Bosch 69136 Original Equipment Replacement Electric Fuel Pump: Automotive Amazon.com: Bosch 69136 Original Equipment Replacement Electric Fuel Pump: Automotive
UVCH Clips $16.00
Amazon.com: Ford 2C3Z-14A163-AB - RETAINER: Automotive Amazon.com: Ford 2C3Z-14A163-AB - RETAINER: Automotive
Cigarette Outlet $11.00
Amazon.com: Ford, ADDITIONAL SOCKET Assembly, BL3Z-19N236-A: Automotive Amazon.com: Ford, ADDITIONAL SOCKET Assembly, BL3Z-19N236-A: Automotive
Outlet bezel $12.00
Amazon.com: Ford F81Z-15K040-AA - RING - LUMINOUS - CI: Automotive Amazon.com: Ford F81Z-15K040-AA - RING - LUMINOUS - CI: Automotive
Alternator $150.00
Amazon.com: Bosch AL7606N New Alternator: Automotive Amazon.com: Bosch AL7606N New Alternator: Automotive
Under seat storage $165.00 2000-2016 Super Duty F250/F350 SuperCab DU-HA Under Seat Storage Unit / Gun Case 20031
Steering Stabilizer info for 4x4
F81Z-3E652-AA $1.00 Bracket
N811656-S426 $2.00 U-bolt
N620482-S301 $4.00 U-bolt nuts - 44 ft lb
F81Z-3E651-DA $75.00
Amazon.com: Bilstein 24-158848 Monotube Steering Damper, Front 46mm: Automotive Amazon.com: Bilstein 24-158848 Monotube Steering Damper, Front 46mm: Automotive
N606084-S426 $1.00 dampers bolt
N606083-S426 $1.00 damper bolt
N620483-S301 $2.00 damper nuts 66 ft lb
Instructions $0.00 https://www.ford-trucks.com/forums/1...er-w-pics.html
Old Feb 24, 2016 | 06:34 PM
scotttahoe's Avatar
scotttahoe
Nice work on the oh **** list! Very smart!
Skip1970's Avatar
Skip1970
I like list
Old Feb 24, 2016 | 06:49 PM
z31freakify's Avatar
z31freakify
Nice job Sous.
Old Feb 24, 2016 | 08:11 PM
bigb56's Avatar
bigb56
So that Bosch alternator will bolt right on to the 7.3? Amazon says it will not fit my 2002 7.3
Old Feb 25, 2016 | 03:29 AM
Tugly's Avatar
Tugly
Great list! My wife bought the DU-HA under-seat storage for Stinky (on my Birthday), as well as the toupee for the dash. I can't say the Donald Trump dash serves any real purpose, but that DU-HA is a huge help.
Old Feb 25, 2016 | 05:08 AM
Jaime74656's Avatar
Jaime74656
It gives stinky a hair piece LOL
My list is simple, Tools (39 piece Duralast kit from the Autozone [life time waranty]), Hi-Lift jack, kit to use for pulling self out of situations, and a CPS incase the original breaks...and the spanner to change it out...
Old Feb 25, 2016 | 05:13 AM
Tugly's Avatar
Tugly
Originally Posted by Jaime74656
It gives stinky a hair piece LOL...
Old Feb 25, 2016 | 06:46 AM
Sous's Avatar
Sous
FTE Emeritus
No, but with a bit of "persuasion" it will fit. The case is a bit larger so the mount for the alternator needs to be ground down a bit, or you can shim the alternator to bring it up. Some go the extra mile and turn/clock the casing to match the stock 110 amp, but I would not make that decision to do so until the alternator is mounted.
It is a higher output alternator that is found on the 6.0 diesel trucks, but not $200-$300 like you see most of the time. Also, I feel more comfortable (maybe false hope) with a new Bosch than just some random Autozoo or O'riely knock off.
Old Feb 25, 2016 | 06:48 AM
Sous's Avatar
Sous
FTE Emeritus
Ya, the instant I saw that thing it went on my list. Currently I have chains, tools, straps, triangles and dog leashes just randomly pushed under the seat. The storage bin is a must in my opinion.
Old Feb 25, 2016 | 06:50 AM
Sous's Avatar
Sous
FTE Emeritus
I hear ya, I am in the planning stages of building an overland kit similar to like what Jesser did here.
Old Feb 25, 2016 | 09:36 PM
Skip1970's Avatar
Skip1970
how much is it?
Old Feb 25, 2016 | 10:08 PM
bigb56's Avatar
bigb56
Originally Posted by Skip1970
how much is it?
$150 (see original post)
Old Feb 26, 2016 | 01:02 AM
Skip1970's Avatar
Skip1970
thank you kind sir/
Downunder F250
16
Jan 5, 2019 11:48 AM
Downunder F250
Jan 2, 2019 08:39 AM
lawdawg79
Aug 11, 2015 01:02 PM
PrinceValium
6.7L Power Stroke Diesel
22
Apr 3, 2012 11:47 AM
Mr. Finch
Dec 18, 2011 10:29 AM
