Sponsored by: Real Truck
transfer case conversion ???
Old Dec 9, 2007 | 01:20 PM
afbrian13's Avatar
afbrian13
Question transfer case conversion ???
99 250 SD, v10, auto, 4x4, ESOF, XLT
Just rolled 85,000 without a hickup on anything but i was thinking about the automatic transfer case shifting. I was curious what's different between the manual vs auto transfercase trucks? If (or when) I ever have problems in the future I would like to just make it a manual (like my '70 - you know its engaged)
Any insite? Is it just a lever that bolts onto the actuator mount? (obviously the hole in the floor, i'm talking mechanically)
Thanks, just planning ahead,
Brian
Old Dec 9, 2007 | 01:24 PM
1EVILCREWCAB's Avatar
1EVILCREWCAB
from what i've seen the electric shift model cases can't be converted to manual, the shift motor is on the back side is it not?
Old Dec 9, 2007 | 04:25 PM
1975StroppeBaja's Avatar
1975StroppeBaja
I am interested in this topic for the same reason (planning ahead). I've only had my SD for a month now and the 4x4 **** seems to work really well but my '94 Explorer has left a bad taste in my mouth for "4x4 on the dash".
I've owned it since 80k miles (151k-ish now) and its had trouble engaging the entire time. Always takes 4 or 5 tries if you haven't had it in 4x4 for a month or so. I've looked into converting my Explorer and the transfer cases are totally different so that would be a little pricy. For now, when its at its worst, a few raps on the shift motor with the BFH takes care of it for several months. When it works well it sounds like really weak clicking under there and finally goes in. At least my SD makes a distinct clunk as soon as you turn the ****.
So, I have no intention of doing this until it becomes a problem but the info would be good to know.
Old Dec 9, 2007 | 07:41 PM
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The NP271 T-case is the manual shift model, and the NP273 is the electric shift (ESOF) model. I doub't it's as easy as swapping the linkages over...
Old Oct 31, 2011 | 09:00 PM
NavyMIDN08's Avatar
NavyMIDN08
Old post, even ancient.
I searched and searched, and can't find the answer. What do I need to do to convert from ESOF to manual. its not as easy as just swapping cases, my case is a hybrid dodge/ford unit to bolt up to my nv5600, and that means I couldn't recoup costs by selling the old case as easy as normal.
So, does anyone have experience converting? What all is involved? any aftermarket sources make a simple kit?
Sorry to dredge up an old post. If i missed the information somewhere else, please post up a link. I'm sick of electronic failures...
Old Nov 2, 2011 | 08:08 AM
NavyMIDN08's Avatar
NavyMIDN08
nobody? I'm sure someone knows the answer to this one...
Old Nov 2, 2011 | 09:41 AM
northwindone's Avatar
northwindone
This might be helpful:
https://www.ford-trucks.com/forums/8...ion-build.html
preppypyro
1997 - 2003 F150
Jul 28, 2017 12:18 AM
ford4x4302
Bronco II
Jun 12, 2017 10:30 PM
fast97gt
1997 - 2003 F150
Apr 1, 2017 11:28 AM
Mike0929
1997 - 2003 F150
Dec 19, 2016 07:53 PM
kbf1961
Jan 25, 2012 03:13 PM
