Sponsored by: Real Truck
Transfer case question
Old Jan 24, 2012 | 11:25 PM
kbf1961's Avatar
kbf1961
I need to tow my 2006 F350 4x4 on a regular basis. Is there any way to put this transfer case in neutral like the old style manual cases
Old Jan 24, 2012 | 11:46 PM
dchamberlain's Avatar
dchamberlain
I don't know the exact answer to that question, but I'm gonna say the odds are against you.
The NV271 (manual) and NV273 (ESOF) transfer cases are essentially identical, as near as I can tell. The difference is just in the shift control shaft. One is designed for a linkage, the other is designed for the shift motor/encoder.
What that all means, basically, is that if you're willing to pull the shift motor each time, you could probably put it in neutral. But the ESOF system in itself is never going to do it.
It's also entirely possible that there are additional differences in the transfer case, and that removing the shift motor isn't even going to help you.
What you probably need if you want to tow it often is a rear axle disconnect system. I suspect they are pretty expensive. Your only other option really is to get good at pulling a section of the rear drive shaft.
Old Jan 25, 2012 | 01:01 AM
GregsSD's Avatar
GregsSD
Is there even a neutral position on th NV273?
I have heard that there is no way to put it in neutral at all.
Old Jan 25, 2012 | 01:08 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
What is the difference between 2wd ESOF and neutral on a manual 4x4?
Old Jan 25, 2012 | 02:02 AM
dchamberlain
I'm not entirely sure. If I were NV, I would've built two identical transfer cases, with the only difference being the design of the gear selector input. Why design any more differences than necessary. But I'm not NV.
Either way, there is no way to do it electronically. It's either the maybe possibility of removing the shift motor, or some sort of rear drive shaft disconnect, or removing the rear drive shaft.
Old Jan 25, 2012 | 02:09 AM
dchamberlain
I'm assuming you mean, what is the difference between 2wd and neutral on a manual transfer case. 2wd is 2wd. Neutral is neutral. Neutral is no connection between the input shaft and either output shafts. Freewheeling. Better have a good working parking brake. Etc.
Actually, way back I had a tow truck guy tell me that you didn't want to tow even a manual transfer case 4 wheels down in neutral. You always wanted to pull the drive shaft. That they still had a pump driven by the input shaft, and in neutral the transfer case wouldn't get proper lubrication. This was on my Dad's '96. I know both the NV 271 and 273 have oil pumps, cause I've seen them in the diagrams. However I'm suspicious of his claims. It seems to me the pump would probably be driven regardless of the gear selection. He probably just wanted the extra charge for pulling the drive shaft. Dunno.
Old Jan 25, 2012 | 09:37 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Oh ok. So if thr transmission was in neutral, there would still be a connection to the wheels?
Old Jan 25, 2012 | 10:36 AM
LSchicago2's Avatar
LSchicago2
Yes. Only a manual transfer case will disconnect the drive shaft from the trans. If you have ESOF, you will have to keep the switch in 2wd, & unbolt the rear drive shaft if going over 50 miles or 35 mph.
Old Jan 25, 2012 | 11:07 AM
dchamberlain
Are you asking about the transmission or the transfer case? Cause your original question you said transfer case and now you said transmission.
On a manual transfer case, if you put the case in neutral, there is no connection between the transmission and the wheels, at all, front or rear.
Old Jan 25, 2012 | 02:51 PM
mwsF250's Avatar
mwsF250
The last time I looked at diagrams, I did notice some differences in the innards and parts lists between the 271 and 273.... There are some extra synchronizer parts in the 273. Would that make a difference in towability (assuming you figured out a way to select a neutral with 273)? I don't know.
Yes, there is a pump in the 271, but since it is on the OUTPUT shaft, I believe it still functions if truck is towed 4 down and in neutral.
http://www.drivetrain.com/images/sto...awing_list.jpg
Old Jan 25, 2012 | 02:54 PM
dchamberlain
The extra synchronizers are probably so the TC can spin the front drive axle up from 0 to 50 MPH quickly. So yeah, there probably are more differences. I never figured taking the shift motor off was that great an idea anyway.
And yeah, I figured that tow truck dude was full of it.
Old Jan 25, 2012 | 02:57 PM
mwsF250's Avatar
mwsF250
Per my previous post, the transfer case should be fine. But...
There would still be a connection between the rear wheels and the output shaft of the transmission. The output shaft would be spinning, but the fluid pump for the transmission is on the input shaft which would not be spinning - so no fluid being pumped. Eventually, the bearings on the output shaft would not have enough lubrication to survive.
Old Jan 25, 2012 | 03:00 PM
ford390gashog's Avatar
ford390gashog
Actually, way back I had a tow truck guy tell me that you didn't want to tow even a manual transfer case 4 wheels down in neutral. You always wanted to pull the drive shaft. .
BINGO!!!!!! The pump will not turn in these T cases in neutral. You either want to drop the drivelines or look into a drive shaft disconnect.
Old Jan 25, 2012 | 03:13 PM
mwsF250's Avatar
mwsF250
Take a look at the diagram I linked. Item 51 is the pump, and it looks like it has to be driven by output shaft.
PQH350
27
Mar 11, 2018 07:28 PM
jem44357
Jan 27, 2010 09:13 AM
17fordguy
Jun 9, 2009 08:15 AM
shocker91
Jun 14, 2003 11:40 PM
Rodeojoe
1978 - 1996 Big Bronco
Feb 27, 2002 02:45 PM
