Sponsored by: Real Truck
Sony stero removal?
Old Nov 30, 2007 | 12:26 PM
FoxRacin17's Avatar
FoxRacin17
Sony stero removal?
I need to know how to get a Sony stero out. I bought a removal tool and there are no holes to use. It kinda looks like it just comes out but i dont know. I dont want to break anything. Im replacing it with a newer Sony with more options. They are almost exactly the same size so the new one should fit in the hole right? And the wiring harnesses are the same on all right? Thanks in advance for any help. It is greatly appreciated.
Old Nov 30, 2007 | 12:53 PM
bigrey6306's Avatar
bigrey6306
Usually the aftermarket radios come with their own removal tools
you have to pop off the outer trim cover, and insert them on the sides of the radio, then pull out...
if you dont have the radios removal tool, try sticking something else in there and get it to release, it will then slide right out, or should...
Old Nov 30, 2007 | 01:16 PM
GnFnRs's Avatar
GnFnRs
check the sides of the sony right under the trim ring. if you can see a chrome piece on each side that hold the trim on then you can push in on them and it will slide out. if there are no chrome clips on the sides then ya have the newer sonys and ya have to have the tool or something thin and wide to slide down each side of the radio..there are small grooves to slide them into.this will release the locking tabs on the sides.
Old Nov 30, 2007 | 01:17 PM
FoxRacin17's Avatar
FoxRacin17
mine has the chrome clips. thanks.
Old Nov 30, 2007 | 01:40 PM
FoxRacin17's Avatar
FoxRacin17
well, i got the chrome clips in but it still wont come out. idk how im gonna do this.
since i already have the sony in it, will i need any new wiring harnesses. someone told me that i will. i would think it would already have them.
and it should fit into the same hole right. theyre the same size.
Old Nov 30, 2007 | 01:54 PM
FoxRacin17's Avatar
FoxRacin17
ok, i got it to slide about 4 inches out then it catches something. ?????????
Old Nov 30, 2007 | 02:17 PM
vwovw's Avatar
vwovw
have you removed the darker colored plastic sorround? the theives got mine twice within seconds. viper alarm going off and everything. anyways they removed the plastic cover thats around all instruments heater,speedo you know. just be carefull air bag shut off wires stay on till you remove switch. you should be able to see what your caught on.
Old Nov 30, 2007 | 02:24 PM
rwilimo's Avatar
rwilimo
At 4" it is likely the wiring catching something. Work it in and out and see if it comes loose, if not you will have to get behind there to free the wiring.
Old Nov 30, 2007 | 02:33 PM
bigrey6306's Avatar
bigrey6306
Thats what I was gonna say, prob wiring snagged
Old Nov 30, 2007 | 02:57 PM
FoxRacin17's Avatar
FoxRacin17
that sucks. i hope it comes loose easy.
Old Nov 30, 2007 | 03:35 PM
2000silverbullet's Avatar
2000silverbullet
Can you pull the dash enough to get your hand in there to "feed" the wires out while you pull the stereo out? The dash on my '00 just pops free with a good pull....
Old Nov 30, 2007 | 05:00 PM
RacerLT250R's Avatar
RacerLT250R
The wiring harness should be the same and the stereo removal tools that come with the new radio should work for the old one as well. If you drop the glove box down i think you can snake your hand up behind the radio
Old Nov 30, 2007 | 05:30 PM
GnFnRs's Avatar
GnFnRs
in my excursion i could reach up fromthe bottom of the dash by the throttle pedal. my wires hung up on the tab at the bottom of the radio where the round bar runs through
Old Nov 30, 2007 | 10:15 PM
FoxRacin17's Avatar
FoxRacin17
thanks for all the replies. i dont see this being too much of a problem now. yall are ok. thanks.
ManfredVonRichtofen
Feb 18, 2015 10:20 PM
WGFA
Nov 25, 2012 09:37 AM
eagles8022
Aug 19, 2006 11:39 AM
elwilley
1997 - 2003 F150
17
Apr 16, 2005 10:26 AM
CountryBoy685
Mar 26, 2002 08:14 PM
