Sponsored by: Auxito
Axle ID
Old Nov 28, 2007 | 06:21 PM
ranger69f1's Avatar
ranger69f1
Axle ID
This is my first post in this section. My son has a 97, 4x4, 4.6, w/ auto trans. The rear end went out. The right side axle gear has worn into the carrier enough that the c clip holding the axle in fell off, then you can guess what happened.
The left side gear has a tooth missing too.
Now for the fix.
1. Would it be cheaper to rebuild it or pull a complete rear from the bone yard?
2. How do I tell what axle I have?
3. Is there a good donor other than the same model truck to find one in?
If it helps, this is how the tag on the cover reads: S862B
3 55 88 6M17
Thanks!
Old Nov 28, 2007 | 06:36 PM
Ford Fx4's Avatar
Ford Fx4
ha, That was the extact as my very first truck, anyway you have a 8.8 rear end, with gears being 3.55 open
Old Nov 28, 2007 | 06:41 PM
Ford Fx4's Avatar
Ford Fx4
Originally Posted by ranger69f1
Now for the fix.
Thanks!
1- Probably cheaper to find a good used one in a junk yard.
3- I believe any 1997-2003 8.8 rear end will work, someone correct me if i'm wrong.
Old Nov 28, 2007 | 07:10 PM
Bobby82490's Avatar
Bobby82490
Talking
Any 8.8 from a 97-03 f-150(96 and older had different lug pattern) that has 3.55s should work. Try to find one that says something like 3L55..... this means its a 3.55 ratio w/limited slip. I think all of these trucks came with rear ABS, so you shouldnt need to worry about that. Also find one that has the same brake setup, if you go with the other it will make the swap harder.
Also if you want a stronger axle get a 9.75 axle out of the 97-03 with the 5.4l. When you get an axle out of a salvage yard, it would be a good idea to take the cover off to inspect the interals and check for alot of play(since you would probably want to change the fluid anyway, it uses 75-140 syn. fluid)
Old Nov 28, 2007 | 07:13 PM
Bobby82490's Avatar
Bobby82490
Talking
4.2L and 4.6L come with the 8.8 and the 5.4l comes with the 9.75
Old Nov 28, 2007 | 08:02 PM
ranger69f1's Avatar
ranger69f1
Thanks for the info. The search starts tomorrow!
fbavaro1
16
Sep 13, 2023 11:35 PM
Toyman
1978 - 1996 Big Bronco
Jan 28, 2015 09:13 AM
thundersnow70
18
Jan 5, 2014 08:19 PM
fnx4wheeler
Nov 26, 2010 09:21 PM
DarkNite
Oct 20, 2009 11:26 AM
