1978 - 1996 Big Bronco
3/4 ton axles in a 79 Bronco
Old 01-27-2015, 12:04 PM
Toyman's Avatar
Toyman
Toyman is offline
What are everyone's thoughts about this. I found a set of axles locally. I know the truck axles are leak spring, but the axle housings are identical so all I would need to do is swap all the components from the front axle to my housing and I am good to go.
Could there be a down side to having large brakes, and full float rear axle?
Old 01-27-2015, 03:28 PM
Kemicalburns's Avatar
Kemicalburns
Kemicalburns is offline
what many do is swap from the knuckle out to gain 8 lug up front and then swap a FF rear diff out back. there should be plenty of write ups on how to approach this as some use chevy parts to accomplish this.
the key to an upgrade like this is make sure that what ever front end setup you go with those parts are readily available at the parts store in the event you have a failure down the road.
Old 01-27-2015, 03:35 PM
Toyman's Avatar
Toyman
Toyman is offline
I found a set of 3/4 ton axles from a 76 F250, I knew I would need to gut the front to get the gearing and use the outer parts for it to work on my coil sprung set up.
I guess my biggest question is there much of an upgrade, other than 8 lug wheels and the full float rear? I can swap in hardened axles in the front, and upgrade the rear with disc brakes and mosher axles for strength.
Old 01-27-2015, 04:13 PM
bigzirb's Avatar
bigzirb
bigzirb is offline
My Bronco had a rear Dana 60 out of a 76 F-250 in it when I bought it. I swapped everything on the front axle from the Ball Joints out from a 76 F-250 (Dana 44HD) axle to gain the 8 on 6 1/2 bolt pattern and the larger dual piston disc brake calipers. You will also have to swap to the F-250 outer stub shafts as the inner and outer axle shafts of both axles are different lengths. I also found a site that showed how to swap the exact same discs and calipers onto the rear Dana 60. Here's there site if you are interested.
NORTH COUNTRY SPECIALTIES ®
Here's the link to my build thread with the pics of me swapping the front. The front swap info starts around post #31.
Also remember that you will NOT be able to use the front gears from the F-250 in the bronco axle. The Bronco is a high pinion where the F-250 is a low pinion axle.
If I had purchased my Bronco with the factory axles in place I probably would have just done upgrades to them as I found the weak points. I didn't have much choice as the rear had been swapped and I had all of the parts on hand to swap the front from 2 F-250's that I had scrapped years ago.
It is really up to you if you want to spend the money to sway the F-250 parts and have stock strength 3/4 ton axles or if you want to spend the money and upgrade you factory axles. I'm guessing that you could upgrade everything to stronger than the F-250 for less time and money if you are really in the market to upgrade.
Just my 2 cents.
Let us know what you decide.
Old 01-28-2015, 09:13 AM
Toyman's Avatar
Toyman
Toyman is offline
Lookin like after some research I am not gaining much by going to 3/4 for my use. I will just upgrade my parts as I break stuff.
Thanks for the replies and the links!
Aberasturi_c
10-13-2008 10:42 PM
tabascom16
15
02-27-2008 05:29 PM
iwannabebig
Bronco II
11-28-2004 09:05 AM
trailhunter
11-20-2003 05:37 PM
greginboise
01-22-2001 09:27 PM
Quick Reply: 3/4 ton axles in a 79 Bronco
