What is the stock wheel width on a '02?
Old 11-27-2007, 07:28 AM
02GrayPowerStroke's Avatar
02GrayPowerStroke
02GrayPowerStroke is offline
What is the stock wheel width on a '02? Its on a F250 4X4 Offroad, if that matters.
I installed a set of 285/75-16 BF Goodrich T/A KO's D ply. And when the first time I towed (10K) I was all over the road. I just want to make sure I have them on the right size wheel.
Thanks
Old 11-27-2007, 07:32 AM
Pocket's Avatar
Pocket
Pocket is offline
Wheel width is either 7.5" or 8", can't remember for sure. However the 285's fit just fine on the stock wheel.
Check your tire pressure when towing. The BFG's get squirrely when there's not enough air and you are pulling a load.
Old 11-27-2007, 07:46 AM
02GrayPowerStroke
I am running at max psi, 65. Looks to me like I am not running on the entire tread. Mainly 85% of the center of the tire. I am thinking I may need to come down on the psi.
Old 11-27-2007, 07:55 AM
02GrayPowerStroke
BTW Pocket, Looked at your site. Great pictures!! Man I wished I lived close to somthing like that, WOW. Instead I live in the arm pit of Texas.
Old 11-27-2007, 07:58 AM
Pocket's Avatar
Pocket
Pocket is offline
LOL, I used to live in the armpit of Texas. Houston is where I was born and raised. So I've got the Texas roots, but now I get to play in the Rockies.
Old 11-27-2007, 08:32 AM
2002f2507.3LPS's Avatar
2002f2507.3LPS
2002f2507.3LPS is offline
should u have E rated tires? just a thought...
Old 11-27-2007, 09:09 AM
RedBoat's Avatar
RedBoat
RedBoat is offline
Rather Be Floatin
Stock wheel width is 7.5". My BFG's are E rated and max press is 80psi.
Old 11-27-2007, 09:17 AM
02GrayPowerStroke
Yup, just talked to BFG, they said the only thing the tire shop should had put on there is an "E". I call the shop and they are going to replace them for $9 a tire. I am happy with that.
mueckster's Avatar
mueckster
mueckster is offline
I am running 285 Yokohama A/T on stock rims. I have to run 55 psi in front and 50 in back to get an even wear pattern. Drives fine though. I up the pressure in the rear when I pull my fifth wheel camper.
Old 11-27-2007, 05:00 PM
rebelchevy02's Avatar
rebelchevy02
rebelchevy02 is offline
Youll find the new tires will do the same. When I put my 285s on they were squirelly for the first couple hundred miles, till the tread wore even. Now they are fine. I run mine at 65psi.
Old 11-27-2007, 08:25 PM
Texas Outlaw's Avatar
Texas Outlaw
Texas Outlaw is offline
Not a liberal...
Mine too. They are 285s. No squirrely feel to them at all, towing or not.
Old 11-27-2007, 09:41 PM
guitarpicr's Avatar
guitarpicr
guitarpicr is offline
Mine are E also - When towing I run 80 rear and 65 front. No problems so far.
