fuel pump
Old Nov 26, 2007 | 06:29 PM
Action4478's Avatar
Action4478
Tappet pic ...here....
Old Nov 26, 2007 | 07:21 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Talking
You can see here the tapet, is at the bottom of the fuel pump.
Old Nov 26, 2007 | 07:31 PM
kawa's Avatar
kawa
Roentgeep:
Please re-post that proceedure on removing a Cali pump that you posted a very short time back.
Rog
Old Nov 26, 2007 | 07:35 PM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
CALIFORNA TRUCK FUEL PUMP R&Rfficeffice" /><O></O>
<O> </O>
Buy a 1/2 " drive, impact socket 1-1/4" and tack welded it to a piece of 1-1/4" black pipe, put it in a metal band saw and cut off the socket leaving only enough to grab the banjo bolt, then ground the tack welds off and ended up with a socket short enough to reach in and unscrew the banjo bolt. Using a 3/8 drive swivel head ratchet and a 3/8 to 1/2" drive adaptor, I managed to break the banjo bolt loose, and finally get it out. I loosened the fuel filter canister and slid it towards the fan, replaced all the fuel lines with Ford factory lines, and new crush washers on the banjo bolt, cleaned the screen on the FPR while I was there. To re-assemble I used a plastic tip off a silicone tube, (new here not used) shoved that into one of the holes of the banjo bolt and then a screwdriver into the tip of the tube,(sounds weird but it worked) shoving the banjo bolt into the fuel line assembly and the pump. Best part of all the truck fired right up with no leaks. Hope this info will help someone on their fuel pump replacement.<O></O>
The fuel dampener was not removed separately; I had loosened the fuel lines at the fuel galleys at the rear of the heads and slid the dampener/fuel line assay slightly towards the firewall. This allowed the lift pump to come pretty much straight up and out of the valley. It really went pretty smooth. I used a little light grease to hold the banjo bolt washers in place until I could get the banjo bolt started back in.<O></O>
for what its worth, Im now running no pulse dampener and it runs the same. Without the dampener it is much easier to get to the banjo bolt also.<O></O>
NOTE thats not mine, only I saved in my PC
jaye
13
May 23, 2010 03:15 AM
herman391
Garage & Workshop
15
Oct 11, 2007 11:26 AM
67nukeford
Mar 29, 2006 11:13 AM
inliner
Garage & Workshop
Mar 18, 2003 05:37 AM
rondog
Oct 27, 2001 02:48 PM
