Stumper Battery Light
Old Nov 26, 2007 | 09:54 AM
Cold_Steel's Avatar
Cold_Steel
Battery light comes on and off.
I have changed both batteries.
I have changed the altenator.
I have check all cables for breaks or cracks and found none.
Any ideas on why light comes off and on?
Old Nov 26, 2007 | 03:29 PM
rebelchevy02's Avatar
rebelchevy02
If its frequent enough, hook up a meter to a terminal in the fuse block under the dash, and see what it says when your light turns on. Start there
Old Nov 26, 2007 | 03:45 PM
clintbonnie's Avatar
clintbonnie
My battery light was going off and on last month.. I found that the small two wires that go out of the top of the altenator, about 2" down from the connector were rubbing on the altenator housing and rubbed thru the insulation. You could hardly see it without using a magnifing glass.. but you could barely see a little copper showing thru.. I reinsulated and reposition them.. been good ever since..
bluetazmanian
Apr 24, 2011 09:19 AM
nstueve
24
Oct 26, 2010 06:42 PM
F350-6
33
Sep 4, 2010 02:24 PM
JE917
Jul 10, 2010 07:27 PM
scott7512
Apr 24, 2007 11:12 AM
