Battery ?
Old Apr 23, 2007 | 07:02 AM
scott7512's Avatar
scott7512
Battery ?
I just changed my alternator yesterday and now the battery light comes on and wont go off. I just replaced the battery last year so I know the battery is still good. Could it be a bad alternator? Thanks in advance.
Old Apr 23, 2007 | 02:59 PM
buzzard's Avatar
buzzard
Did you get wires reinstalled tightly on alternator? That's what I would check first. Next, try disconnecting the (-) battery cable for a few minutes and then reinstall. If the problem persists, take it to the battery store for diagnosis on a machine. It'll pinpoint the problem. FYI, just because your battery is relatively new doesn't necessarily mean it's still good. When I was younger, I worked in an automotive shop that sold tons of batteries and it wasn't uncommon for some to be DOA when brand new.
Old Apr 24, 2007 | 03:27 AM
High_Horse's Avatar
High_Horse
What Buzzard says is correct, also do some simple maintenance like clean the terminals and check your ground cable for corrosion at both connection points. Look for possible corrosion build up going into the cable. A previously weak performing alternator can insue corrosion build up and when a new one is installed the weak point is amplified to trip the light.
Old Apr 24, 2007 | 11:12 AM
c_hohensee's Avatar
c_hohensee
It would not be completly out of the question that your new alternator is no good. As buzzard said a battery shop should be able to pinpoint your problem.
jcd
Mar 24, 2016 02:36 PM
lionsteve
Sep 29, 2010 07:52 PM
dbaker1014
Modular V8 (4.6L, 5.4L)
Sep 27, 2010 09:43 AM
92F150Flare
May 31, 2007 05:23 PM
Buttroast98
1983 - 2012 Ranger & B-Series
Sep 16, 2002 06:16 PM
